Topics49,863
Posts837,548
Posts: 64 |
Since I have had my 1996 4/4 there has been a crease mark in the plastic rear window where someone has carelessly folded it wrongly. Is there an easy fix for this or not. Cheers paul
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
Since I have had my 1996 4/4 there has been a crease mark in the plastic rear window where someone has carelessly folded it wrongly. Is there an easy fix for this or not. Cheers paul My first thought would be to put the hood on, and park it in warm sunlight on a dry day ( I know this is an anathema!). Often this will remove any creases. It's fairly straightforward to replace - a good trimmer should do it easily. Some Morgan dealers will also offer this, but charge 10 times more
Posts: 37,420 Likes: 978
Posts: 37,420 Likes: 978 |
Paul, I don't think there is an easy fix but Woolies will supply you with the Vybak, you just need to find a trimmer that can do the job, unless you are gifted in this area.
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
Try a hair dryer or fan heater from the inside, take care not to get it too hot.
Posts: 64 |
Thanks everyone it's an Everflex roof so not sure how easy it is to replace the window.
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
it should be stitched in so for a trimmer dead easy
