5 members (James B W, JMcL, MATTMOG, Jon G4LJW, Graham, G4FUJ), 293 guests, and 85 robots.
Topics49,849
Posts837,415
DazMog, The Impaler, tlchzj79
#690671 25/02/21 11:00 AM
Pmh44 Offline OP
Since I have had my 1996 4/4 there has been a crease mark in the plastic rear window where someone has carelessly folded it wrongly. Is there an easy fix for this or not. Cheers paul
TBM Offline
My first thought would be to put the hood on, and park it in warm sunlight on a dry day ( I know this is an anathema!). Often this will remove any creases.
It's fairly straightforward to replace - a good trimmer should do it easily. Some Morgan dealers will also offer this, but charge 10 times more smile
Paul, I don't think there is an easy fix but Woolies will supply you with the Vybak, you just need to find a trimmer that can do the job, unless you are gifted in this area.
Try a hair dryer or fan heater from the inside, take care not to get it too hot.
Pmh44 Offline OP
Thanks everyone it's an Everflex roof so not sure how easy it is to replace the window.
it should be stitched in so for a trimmer dead easy
