6 members (linklaw, brownbaker, JohnHarris, Grumpy2, PPD, Topline123), 435 guests, and 42 robots.
Adam12 70
+8Rich 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,549
Members9,215
#692699 10/03/21 12:51 AM
I just bought a rear view mirror for my M3W from Morgan Parts (Melvyn Rutter Limited). It is for the one piece wind screen.
You have to drill a hole in the center wind shield support. I am afraid to drill a hole with the wind screen still mounted.
I cant see how to remove the center wind screen support so I can drill a hole. Has anyone else installed this mirror?
“Looking at other 3 wheelers I would suggest that it’s no closer than 50mm from the top (best not to have the mirror glass above the top edge of the Perspex), but other than that it depends on what is a comfortable height for you.
If you drill in the centre of the upright keeping the drill at 90 degrees to the swept back centre stay. Cover the area to be drilled with masking tape as it’s easier to draw on and stops the drill slipping.”
I created an install guide for this with pictures using the above advice from Melvyn Rutter above. Love the mirror! PM me your email so I can send it to you offline. Easy to drill with the screen attached.
2018 S&S 110th Beetleback
1934 MX4 Beetleback
1965 Corvette Coupe 327/350
I would not be afraid to drill with the perspex. Perspex should withstand almost anything of pressure and deformation. If you are afraid of the drill slipping sideways and scratching the perspex, the above mentioned tape trick is good advice. Even better is to use a pin punch in addition, to mark the drill hole. You could use an automatic punch,one that releases the pin suddenly and impacts the metal when you exort a certain pressure on the punch. On an ordinary punch you would have to use a hammer, not so good. Then use a rather thin burr to penetrate, followed by another burr with the right size.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Use good drills. Drill a pilot hole first. You could use a pointed object to create a starting point instead of a punch. Drill slowly with only enough pressure to keep the drill cutting. Ideally some wood behind would help when the drill breaks through and reduce the chances of cracks. A curved surface makes this difficult! Shaping a piece of wood to match the curve maybe? You could use a tough tape instead to give a little support. Don’t rush the drilling. You are not on a production line with time constraints.
I stick a washer over the site of the intended hole using double sided tape.
With the right sized hole....
great idea!
Rodger
2004 Plus 8 (wife's)
Originally Posted by Robbie Mathisen
... use an automatic punch,one that releases the pin suddenly and impacts the metal when you exort a certain pressure on the punch ... Then use a rather thin burr to penetrate, followed by another burr with the right size.
Exactly what I did. Worked great!
2020 M3W
thanks for the input.
I was a little afraid to drill not knowing how close the edges of the perspex are and not knowing how fragile the windscreen.
I would love to have your install guide
Here is my email address
k9us73@gmail.com
Thanks Tim
2017_Betty - Instructions sent! Start with the small bit first. Will stay in the punch point and not wander.
I have this: Amazon punch
Enjoy.
1934 MX4 Beetleback
thanks for all the help. I drilled a hole but the threaded part was not long enough to screw the nut on. I tried several ways to squeeze the center support so I could get the nut started.
Finally I counter sunk the end closes to the mirror to get a few more screw threads to allow me to screw on the nut.
Went for a drive and I love the mirror. A lot more visibility. [Linked Image]
