2 members (Alistair, ChrisNP), 268 guests, and 100 robots.
+8Rich 86
Topics49,851
Posts837,442
Page 5 of 5 1 2 3 4 5
Thanks Jan.
As soon as the roads are clear and it is a little bit warmer I will continue with the test-driving and re-mapping process.....Hopefully we can find a tune with more horsepower and no rev hang.....:-)
Take care and drive safe!
/David
I don't believe Cain is working on the electronics. MMC piggy backed a "second unit" to the Ford ECU. They are both locked which is why this is so difficult. If you make it work I think quite a few folks on here would like one too.
Thanks for the input John!
The problem is not only that the original ECU in the car is locked it is also that Morgan has left out/blocked the VIN Number so the car has no identity and without identity you cannot make any changes.
First problem solved the car is running on a "new" ECU which is open and has a VIN No and we have already tried some new tunes including the original Mustang tune, but that did not work and fault codes were plenty...:-)
The number of possible changes to all the parameters in the ECU is quite vast so we definitely have some more work to be done before we can nail a good tune....
But it might turn out that I still would need to go for the lighter flywheel as well to get it perfect. Maybe I should drop Caine a line and ask him about the flywheel and if he have done any remapping?
cheers
/David
