0 members (),
283
88
Topics49,860
Posts837,485
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Good morning all, I was doing a bit of reading last night and saw that a vented cam cover was mentioned, is this something the factory did on later cars or was it a modification elsewhere? I presume in response to the heat issues around the cam belt. I was curious to see a picture of one to compare against the original (mine has what I presume is the original with spacers). Thanks
Aero 8 GTN #11
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
The factory supplied cover has a slot horizontally cut below the rib near the bottom before chrome plating. If you want to diy the mod I would advise a series of drilled holes which will leave a better support for the chrome plating which might start to peel from the long edge of a slot. See mine here http://www.bleazey.co.uk/M3W.htmlPhil
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
Just to add Nick, the factory 'vented' cam belt cover simply consisted of washers added to mount bolts between crankcase and cover.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
The later models have a machined standoff so no washers and no slot in the face.
Posts: 51 Likes: 2
Posts: 51 Likes: 2 |
hi my 2017 has both the 2 horizontal slots and the machined standoff in place of the washers. I took mine off today to have a look at the belt. There was a lot of belt dust. Is this normal or is my belt about to go bad? ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/IMG_2621.jpg)
Interesting, so sounds like three variants:
- Washers added to the mount bolts (as per mine) - A horizontally cut slit below the rib - A machined standoff
Does anyone have a picture of the final one (machined standoff)?
After having oil drip on my belt via the vent gap I am keen to explore a better solution than the washers incase it drips again..
Aero 8 GTN #11
Posts: 1,671 |
The shavings are normal - you need to check the belt regularly for cracks & clear & clean plus change the belt on condition.
Posts: 51 Likes: 2
thanks, I cleaned the belt dust and some oil drippings from the inside bottom of the cover. Mine is a 2017 with 2 slots and machined spacers. Here is a photo (sorry not the best photo) ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/IMG_2625.jpg)
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The belt debris is normal, as Mark says. S&S describe it as "snake skin" and it is the release agent from belt manufacture. There is also a cutout at the base of the cam cover that has been there since the start, probably to let the crank seal oil leakage out. I like the machined spacers on the later covers, I just super glue the washers in place to make things easier.
There does seem to have been a bad batch of belts about and they have shown signs of cracking after just a few thousand miles, well worth checking them regularly. In theory the belt life is 3 years or 30,000 miles (with the vented cover) but "on condition" seems sensible. It is a "safe" engine as the valves and pistons don't try and occupy the same space if the cam belt fails, always nice to know.
thanks, I cleaned the belt dust and some oil drippings from the inside bottom of the cover. Mine is a 2017 with 2 slots and machined spacers. Here is a photo (sorry not the best photo) ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/IMG_2625.jpg) Thanks for the picture, I do like that - might have to order one!
Aero 8 GTN #11
