6 members (Jens, +8Rich, jbk, Graham, G4FUJ, Deejay, MartO), 295 guests, and 81 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,428
#694631 20/03/21 11:38 AM
Felix42 Offline OP
With the eclectic membership of MSCC I am sure there will be a plumbing or hydraulics expert who can answer this conundrum.
The cistern in the downstairs toilet developed a violent water hammer. I found that the float on the ballcock, a stout plastic 150mm sphere in perfect condition, was nearly full of water. I cannot see any orifice through which the water could have entered and nor can I remove the water without puncturing the ball.
The question is: how the Devil did the water get in there?
New balls are available from Amazon.
Felix42 #694644 20/03/21 12:44 PM
I am no plumber though the spheres are usually screwed on to the arm that operates the valve. IF that is the case, then perhaps the seal between the screw fixing and the sphere is suspect. Again if the sphere/float can be unscrewed then blowing air into the threaded link point in it might show up the point of leakage...?
Good luck.
Felix42 #694649 20/03/21 12:59 PM
Normally they a blowmoulded in two halves. Probably a crack at the join.
Also plastic as it ages micro cracks.
Felix42 #694676 20/03/21 02:54 PM
Don’t worry about it - just change it
Tony
1994 Connaught Green Plus 4
Felix42 #694710 20/03/21 05:28 PM
Whatever you do - don`t puncture your ball. It` amazing what you can get on Amazon these days. crazy2
PhilRoyle #694717 20/03/21 05:42 PM
Smile, it confuses them
and sell on eBay. Just choose the right title camera
Felix42 #694750 20/03/21 08:02 PM
simple fix, replace it.
