0 members (),
433
79
Topics49,850
Posts837,427
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
With the eclectic membership of MSCC I am sure there will be a plumbing or hydraulics expert who can answer this conundrum.
The cistern in the downstairs toilet developed a violent water hammer. I found that the float on the ballcock, a stout plastic 150mm sphere in perfect condition, was nearly full of water. I cannot see any orifice through which the water could have entered and nor can I remove the water without puncturing the ball.
The question is: how the Devil did the water get in there?
New balls are available from Amazon.
Posts: 5,440 Likes: 467
Posts: 5,440 Likes: 467 |
I am no plumber though the spheres are usually screwed on to the arm that operates the valve. IF that is the case, then perhaps the seal between the screw fixing and the sphere is suspect. Again if the sphere/float can be unscrewed then blowing air into the threaded link point in it might show up the point of leakage...?
Good luck.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Normally they a blowmoulded in two halves. Probably a crack at the join. Also plastic as it ages micro cracks.
Posts: 103 |
Don’t worry about it - just change it
Tony
1994 Connaught Green Plus 4
Posts: 2,583 |
Whatever you do - don`t puncture your ball. It` amazing what you can get on Amazon these days.
Posts: 11,526 Likes: 312
Posts: 11,526 Likes: 312 |
Whatever you do - don`t puncture your ball. It` amazing what you can get on Amazon these days.  and sell on eBay. Just choose the right title
Posts: 381 Likes: 3
Posts: 381 Likes: 3 |
