3 members (James B W, ScotiaSteve, JohnHarris), 250 guests, and 63 robots.
+8Rich 83
Topics49,860
Posts837,497
Jonny72
#696136 28/03/21 07:54 PM
1340fxd Offline OP
My 1997 +8 has Pirelli P7 Cinturato 205/55 R16 V tyres which are close to needing replacement. Are these OK or are there better tyres for the +8? Thoughts welcome on tyre choice please.
1997 +8 BRG, BMW Z4, Harley FXD, Greeves Silverstone RDS, Kawasaki H2 & Z1000 - no electric cars!
Mine too had them but changed to Dunlop Blu performance very happy with the result -will check the other details tonight.
99 plus 8 indigo
Go for these
https://www.camskill.co.uk/m62b0s291p180985/Toyo_Tyres_Car_Toyo_Proxes_TR1_-_205_55_R16_91W_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB
They are the very best for grip in both wet and dry. Not expensive, slightly faster wearing , but the +8 is a light car so it won't be a major issue.
Andy G
1999 +8 , Indigo Blue.
I put Avon ZV7’s on last change. No complaints. Good wet grip as that is when you need it most! I changed all 5 and rotate the spare to get all 5 in use. Better than having a brand new unused spare that gets old.
Originally Posted by MOG 615
Go for these
I had Toyo TR1's on the previous Roadster and was very happy with them, they had a slight tendency to flat spot on the fronts if not used for a few weeks & assume this was because Mogs run such low pressures, cleaned up after a couple of miles when they warmed up
Sorry they are Dunlop Sport Blu response 205/55 16, havent seen them in NZ but they work very well when pressed.
99 plus 8 indigo
1340fxd Offline OP
Thank you for the ideas - nice to know the choices
Hi, look at this : Tyre test
Happy Morgan +8 (2001) owner
BMW 435i - X Drive
Royal Enfield 500 EFI
Royal Enfield 650 Interceptor
+1 for the Toyos, though you may not end up with the exact same circumference, no big deal, it just means the speedo will under-read a bit, though you can reset it.
Mike H
Bourgogne Franche Comté
