2 members (mickyb, Image),
373
Topics48,355
Posts813,245
Members9,215
Posts: 4,491 Likes: 65
Posts: 4,491 Likes: 65 |
A tip I was given by a RAC fitter was to carry a jack even if you have no spare as the sealing goo works best if the wheel is spun after adding the goo and before fully inflating the tyre. Has anyone else come across this advice?
The Auto Box unlocking make me happy that the auto box on the Plus 8 is old fashioned enough that it can be put into neutral, as long as there is battery power. On the goo instructions you inflate then immediately drive 5 - 7 miles to seal. Auto gearbox locks if you lose total electrical power as I understand it so don’t see how battery would help if no electrics.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
On the Aero auto the gear selector can only be moved with the ignition on and a foot on the brake. Another joy, if the electrics pack up with the key in the ignition you cannot remove the key as again, the car must be in Park to remove the key. So, with no battery power the car is immobile.
Posts: 779 Likes: 18
Posts: 779 Likes: 18 |
if the electrics pack up with the key in the ignition you cannot remove the key as again, the car must be in Park to remove the key. So basically the car is stuck on the side of the road with the key in the ignition waiting for a thief with his own tow truck to take it and put a new battery in. I remember parking an automatic car on a steep slope and couldn't get the key out as for some reason it thought it was not in park even when I pushed up on the gear lever to try make it was certainly as far into park as it could get. Ended up driving 3 miles and then walking back just trying to find a parking spot not on such a slope. I was tempted to park in the same spot facing downhill but the police in that area are very strict about not parking facing the wrong way and would very likely have booked me. Just another one of the reasons all my cars are manual and will be until I have to replace them with electric.
Posts: 13 |
Picked up my Plus Four in September, no jack, aerosol, hammer and centre wheel nut spanner. I have Alloys! Bought a scissor jack and modified the top contact plate to ‘flat’ added rubber packing. I don’t like the aerosol as you loose the tyre regardless.
Plus 4 in Claret Red 3.7 Roadster Crystal Blue Plus 4 in Lapis Blue Plus Four inPalladium Silver
Posts: 1,793 Likes: 47
Posts: 1,793 Likes: 47 |
I've used a product similar to this to repair a tyre: https://www.autoseal.co.uk/about-2/but it is designed to be installed before you have a problem. I believe it can be washed out later if required.
Posts: 2,308 |
I also have autoseal in my Supersport but be aware it can cause front wheel balance..
The large volume +4SS tyres required 375 ml per tyre..but had to reduce fronts to 325ml to bring back into balance.
As Jon says it can be washed out easily if required
Posts: 3,425 Likes: 26
Posts: 3,425 Likes: 26 |
Capta2 - I also have alloys and have decided to purchase a scissors jack and modify as you have. I e mailed the factory and, to be fair, got a prompt reply(!) which gave short shift and said that “they decided not to supply a jack with the CX cars”.They said they would revisit the situation and come up with a more coherent solution- but no jack was forthcoming! Cheers!
Posts: 147 Likes: 11
Posts: 147 Likes: 11 |
I can only say that I wish I had known this before I decided to swap my Roadster in for a Plus Four. Like others I have paid a lot of money for a spare wheel and now find I won't have the tools to change it in the event of a puncture. Having had a classic Plus 4 and Roadster I, foolishly it now appears, assumed there would be the storage place under the rear shelf with the tools including a jack in it. I've had Morgans for seven years and have covered nearly 50,000 miles in them in that time which acrtually is only really six years due to Covid. How do I now continue to do that sort of mileage here and sur le continent without the means to change a wheel? How are you guys planning to overcome this issue. And BTW did MMC really say there's nowhere to put a jack so we don't provide one?
John R Marchant Plus Four JT10MOG "Florence"
I don't understand the issue regarding regarding lack of Neutral on this gearbox at all. My wife now has her second BMW with this gearbox and it has Neutral. How come the Plus Four doesn't?
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Could you get a small scissor jack, wrap it in something and tuck it under the spare wheel maybe? As the car is so light you might be able to find a really small one.
But you're right, for MMC to design and sell a car that can't carry the means of changing a wheel shows just how out of touch they are with people who like to drive long distances.
