0 members (), 323 guests, and 40 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#697048 03/04/21 01:33 PM
My side screens have gone quite opaque over the ensuing 37 years, has anybody got a suggestion on how to clean them, I have a morgan 4/4/4, yes there is such a car, 4 wheels 4 cylinders, and 4 seats, so it has twice as many side screens as 2 seaters. I tried using that stuff that cleans headlights only it made them worse. Any suggestions would be gratefully received. (new ones are unbelievably expensive)
Many Thanks,
Rod (Swordfish)
swordfish #697052 03/04/21 02:07 PM
Just replace the "Perspex"
There are companies that will cut to size or you can buy a sheet and cut it yourself.
It's a bit tricky but if you warm the Perspex, it will bend enough to pop out and replace. Don't attempt to do it in freezing cold conditions.
That's from my 2 seater experience but don't imagine it's that different on the 4 seater.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
swordfish #697056 03/04/21 02:23 PM
Perhaps this helps (there is not only the type of material but also some advices for cleaning):
http://www.talkmorgan.com/ubbthreads.php/topics/499188/re-sidescreen-misting#Post499188
However, the information concerns the material that is currently being used. It was certainly not the same 37 years ago.
In any case, if you want to replace the screens, I would use the current one.
Michael
2018 Plus 4 Sport
swordfish #697060 03/04/21 02:45 PM
GoMog has dimensions & advice for 2 seaters. I did it on my 4/4 years ago & have 2 panels for a 2 seater if that helps anyone.
side screens
swordfish #697068 03/04/21 05:57 PM
I have had success cleaning the windscreen/side screens with a home made vinegar and rubbing alcohol solution, mix 1 cup distilled water with 1 cup of rubbing alcohol and two tablespoons of white vinegar put in a spray bottle and shake well to make sure mixture doesn't separate. Spray directly on glass or perspex and use micro cloth to clean and wipe off.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
swordfish #697183 04/04/21 01:41 PM
Black Rat
Black Rat
Not sure about sidescreens but I use Sovol Autosol to polish plastic headlights that have clouded.
Keith
2013 narrow bodied + 4 Ruby.
