Topics49,898
Posts838,019
Posts: 25 |
My side screens have gone quite opaque over the ensuing 37 years, has anybody got a suggestion on how to clean them, I have a morgan 4/4/4, yes there is such a car, 4 wheels 4 cylinders, and 4 seats, so it has twice as many side screens as 2 seaters. I tried using that stuff that cleans headlights only it made them worse. Any suggestions would be gratefully received. (new ones are unbelievably expensive)
Many Thanks,
Rod (Swordfish)
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Just replace the "Perspex"
There are companies that will cut to size or you can buy a sheet and cut it yourself.
It's a bit tricky but if you warm the Perspex, it will bend enough to pop out and replace. Don't attempt to do it in freezing cold conditions.
That's from my 2 seater experience but don't imagine it's that different on the 4 seater.
Bob
Posts: 314 Likes: 3
Posts: 314 Likes: 3 |
Perhaps this helps (there is not only the type of material but also some advices for cleaning): http://www.talkmorgan.com/ubbthreads.php/topics/499188/re-sidescreen-misting#Post499188However, the information concerns the material that is currently being used. It was certainly not the same 37 years ago. In any case, if you want to replace the screens, I would use the current one.
Michael 2018 Plus 4 Sport
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
GoMog has dimensions & advice for 2 seaters. I did it on my 4/4 years ago & have 2 panels for a 2 seater if that helps anyone. side screens
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I have had success cleaning the windscreen/side screens with a home made vinegar and rubbing alcohol solution, mix 1 cup distilled water with 1 cup of rubbing alcohol and two tablespoons of white vinegar put in a spray bottle and shake well to make sure mixture doesn't separate. Spray directly on glass or perspex and use micro cloth to clean and wipe off.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Not sure about sidescreens but I use Sovol Autosol to polish plastic headlights that have clouded.
