4 members (CooperMan, piquet, IcePack, mph), 283 guests, and 41 robots.
+8Rich 91
Topics49,841
Posts837,312
Page 1,093 of 1,342 1 2 1091 1092 1093 1094 1095 1341 1342
Originally Posted by PlusTim
Thanks for the sharing the fun
We are at Crummock Water in the Lake District on the way to Buttermere on that rare thing -> a dry day at this time of year ...no rules broken , we live near here
The roof on the Roadster came down shortly after the photo
Roll on summer!
Cheers Tim
Good man thumbs
Went back to check the blossoms. Same spot 8 days later. They are coming soon
Others come quicker
But s h i t happens.
Good thing I was alone
1990 4/4 1.6 Ford CVH Sold
2014 +4 2.0 Ford
2005 BMW Z4 2.2 6Cyl Sold
Went to put fresh petrol in the tank. Shell garage across town. Returned home via a 30 mile detour to blow the cobwebs away. Car running well. First drive “ for the hell of it” for many weeks. It felt great , roof down, wind in the hair ( I had a haircut last week) smiles.
Patio being laid from Tuesday so next spin won’t be until that is done. Weather permitting just a couple of days. smile
We took advantage of the beautiful weather today (tomorrow the temperature will drop just above freezing) and made a trip to the Wachau, where the apricot trees are currently in blossom:
We crossed the Danube on a small ferry:
On the way home, there was some excitement: after a photo stop, the Morgan wouldn't start. scared
When I pressed the start button, nothing happened at all. ooo
The power supply seemed to work fine. Several attempts to start the car were unsuccessful (the spare key was at home).
Checked the main fuse for the starter: o.k.
Swapped the relays for the fuel pump and immobiliser: no improvement.
Then checked all fuses. After removing and reinserting the fuse for the immobilizer, tried to start: success joy
Switched the engine off again and started it again: the engine started reproducibly.
Conclusion: In case of starting problems, try to remove the fuse of the immobiliser and reinsert it (apparently causes a kind of reset).
Michael
2018 Plus 4 Sport
Lovely pictures Michael, glad you got her going again with your tenacity under pressure thumbs
It could be the ring by the switch that connects to the immobiliser. DaveW posted a thread on that.
Just rub the ignition key fob flat against the barrel and the immobiliser light will extinguish.
Then you have 30 seconds to put the key in and start.
Cold weather seems to make it worse.
Thanks for the tip. I tried that, but it didn't work. Only removing and reinserting the fuse was successful.
Michael
2018 Plus 4 Sport
The day after:
(The pictures are not taken in the Wachau but in my garden, which is only 100 meters higher than the Wachau).
Michael
2018 Plus 4 Sport
I have one or two things that struggle in cold weather grin2
