Morgan Aero 8
8 members (Davetherave, Image, Luddite, RichardV6, BLUE+4, JohnHarris, BobtheTrain, Graham, G4FUJ), 319 guests, and 62 robots.
+8Rich 69
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,717
I am wanting to upgrade my air filter to a K&N pannel type. can some one tell me where the filter is located and how to get to it please !
Cheers
Tom
Morgan Plus 8 Speedster
2015 Defender 90 - Twisted/Bowler Mix
Formerly known as Aldermog
In the O/S wing, accessed by removing a panel on the underside of the car, behind the front wheel arch. Air is drawn in through the louvres on the wing.
I'm told you need the car up on jacks to do the job as the filter element is taller than the ground clearance....
I did think as much, thank you for confirming, so much for a easy swop frown.....another job for the weekend...
I've PM'd you
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Air is drawn from the front and over the top of O/S front wheel on my car.
Martin (Deano)
Deano,
This photo shows on Tarka the hose from the engine bay into the wing and than the air filter housing. There is no inlet from the engine bay or the under the wing.
Tarka is a July 2013 build, not really a surprise cars differ....
Have fun. Here with the airfilter box removed.
You need to:
remove bonnet
remove cowl
remove wing
They installed a removable plate in the bottom at some point, so in theory the air filter could be removed without all that effort...
I took this photo in the factory in 2017 of a Plus 8 in build, and it shows the air box, but I'm not certain how the clips could be undone to allow the filter to be replaced...
So it is still a bit of a mystery.
Holy cow.....! I do have a hatch, I will have a look first I think!!! Jeeps....
Do you think there is any benefit in adding an upgraded air filter?
