1 members (Rex_tulips),
250
42
New
Topics48,365
Posts813,354
Members9,215
Posts: 186 Likes: 3
Posts: 186 Likes: 3 |
Hi all,
took the car out today (1997 +4 T6 rover engine) and it was running like a pig, hard to get it to above 50 and coughing nd spluttering all the way, as luck would have it I was passing BHM and called in to have a chat with Keith who diagnosed it as an ignition problem and told me to limp the car home clean all the ignition leads and distribution unit and run the car in semi darkness and observe the plug leads etc for signs of failure in the form of arching out leads etc. This I have done and sprayed the system with a mist of water to enhance any shorting out, nothing was evident but the car still appears to be running on only 3 cylinders or so. I believe that the leads are pprobarbly original but all seem well in that department.
Any ideas would be a help now before I renew the leads etc.
This has only just started to occur now, before this all was well.
Thanks in advance.
Why is there only one monopolies commission??
Rob B.
Posts: 5,056 Likes: 318
Posts: 5,056 Likes: 318 |
Can you pull off the plug leads one at a time to isolate it to one cylinder? (The one where removing the lead doesn't have any effect, at the risk of mansplaining 🙂) .... then try switching plug leads if length allows between the offender and a good'un and see if the misfire moves with it .... similarly with the plug if that doesn't furnish a result
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
With engine running, remove and replace plug leads one at a time. The one that makes no difference to sound will be the faulty one. (possibly ignition lead or sparking plug) You may wish to do this with a rubber glove on in case you happen to touch a leaky bit.
Posts: 35,791 Likes: 472
Posts: 35,791 Likes: 472 |
To be honest if they are original I'd get a new set of leads, distributor cap and spark plugs it's a cheap option in the long run. When I bought my 1999 Plus 8 seven years ago with 19,000 miles on it was the first thing I did £50 fit and forget, and I've got eight of most things  .
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
I have to agree with +8 Rich, and if the distributor is an old style one with a contact breaker I'd think about electronic ignition and a solid state distributor. A bigger, hotter spark.
Posts: 26,761 Likes: 425
Posts: 26,761 Likes: 425 |
The ECU measure the manifold vacuum via a pipe that goes from the manifold on the drivers side to the ECU (the box on the scuttle above the steering shaft). They can & do rot. If they do the vacuum goes all over place. Take it off & bend it if it cracks or is hard replace it.
Posts: 3,383 Likes: 13
Posts: 3,383 Likes: 13 |
Guys I would caution pulling off plug leads. This can generate a back EMF and damage the ignition system. The correct procedure to do a power balance (that’s what your describing) is to SHORT out the HT not open circuit it. You can do this by pulling the HT lead spark plug end boot or by using a steel extension piece to the spark plug terminal (can be made with a slotted tube of thin metal) and shorting it to the cylinder head with a large screwdriver.
Crypton and Sun cabinets came with a box of such adapters. Google Gunson 77074 Spark Plug Extension Leads With Spark Tester
BR Colin
Posts: 186 Likes: 3
Hi all,
Update, it is definitely number 2 cylinder. I think it is time to replace the leads and plugs my next question is what are the best plugs (size and make) and leads to buy?
At the moment the leads are Lucas RISTS suppression 1015.
All advice welcome and a help.
Cheers chaps.....
Rob B.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Oh, Lucas Rist's are old, probably the originals from when the car was built
If the car's been stood over winter old petrol won't help with running either
Rob (Buy British) will know what Plugs & HT leads fit
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
I went for some big Magnecor Silicon 8.5mm on my xflow. Bit pricey but have had no issues. Cheaper/similar options out there.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
