2 members (mph, +8Rich), 367 guests, and 90 robots.
Topics49,848
Posts837,402
DazMog, The Impaler, tlchzj79
No noise on the Plus 6 -- oddly the Aero has always squealed like a stuck pig after I wash it but after a few pedal presses brakes are quiet again.
2016 Carmine Red 991.2 C4S
Originally Posted by Almond
The brakes on my Plus Four started squealing as I drove it off the forecourt and they haven't stopped since. Its booked in for a service fix at the dealer next month. I'm told its an alignment issue (how the pads are presented to the disc) rather than a pad/disc material issue so I think cleaning is only a very temporary fix.
How the alignment issue will be addressed I am not sure but new calipers or caliper mounts or shimming somewhere seems most likely. I'll update when I know more.
CX brakes are not a strong point as many have pointed out - even on the less swift Plus Four. They are certainly easy to modulate and give good decelleration eventually - if you push hard enough and far enough - but mine has very long pedal travel, poor intial bite and is a bit spongy. Again the dealer has promised to look at it but I fear someone will tell me it is a CX charecteristic.
Many thanks. I will speak to my dealer and ask them to speak with MMC about the alignment fix.
I dont get this. The brakes arent made by MMC but by some big outfit like Brembo surely
But developed for a much heavier car ??
The solution apparently involves a re attachment of the caliper with different bolts and some washers - the factory supplies a “kit” - I await mine!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
