Topics49,848
Posts837,407
Posts: 4,649 Likes: 123
Posts: 4,649 Likes: 123 |
No noise on the Plus 6 -- oddly the Aero has always squealed like a stuck pig after I wash it but after a few pedal presses brakes are quiet again.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 33 |
The brakes on my Plus Four started squealing as I drove it off the forecourt and they haven't stopped since. Its booked in for a service fix at the dealer next month. I'm told its an alignment issue (how the pads are presented to the disc) rather than a pad/disc material issue so I think cleaning is only a very temporary fix.
How the alignment issue will be addressed I am not sure but new calipers or caliper mounts or shimming somewhere seems most likely. I'll update when I know more.
CX brakes are not a strong point as many have pointed out - even on the less swift Plus Four. They are certainly easy to modulate and give good decelleration eventually - if you push hard enough and far enough - but mine has very long pedal travel, poor intial bite and is a bit spongy. Again the dealer has promised to look at it but I fear someone will tell me it is a CX charecteristic.
Many thanks. I will speak to my dealer and ask them to speak with MMC about the alignment fix.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
I dont get this. The brakes arent made by MMC but by some big outfit like Brembo surely
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
I dont get this. The brakes arent made by MMC but by some big outfit like Brembo surely But developed for a much heavier car ??
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
The solution apparently involves a re attachment of the caliper with different bolts and some washers - the factory supplies a “kit” - I await mine!!
