7 members (SteveT, Tony Quinn, Ian Wegg, TeddyAds, GBpluseight, TBM, Grumpy2),
187
38
Topics49,844
Posts837,354
Posts: 8,663 Likes: 408
Posts: 8,663 Likes: 408 |
I had that problem & wiring the side lights to the ignition not only solved it but made it safer I guess. But how do you leave your side lights on if parking on the street at night in a position which requires them? Or is that old outdated highway code thinking? A relay to power the sidelights with ignition on would allow them to work normally on the sidelight position of switch when engine off.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
My sidelights were fine .... except that the bulb holders were very badly corroded ..... I cleaned everything up and removed the old bulb holders .... replaced them with wedge led bulbs and rubber matching holders that zip-tie easily to the fixing strips inside ... end result is brighter and hopefully more reliable .... and much more resistant to corrosion. ![[Linked Image]](https://www.tm-img.com/images/2021/04/25/20210425_093517.jpg) K
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
My Roadster S1 is now equipped with LED in wing ligths and pilot lights in the headlamps. As far as I know, there is no MOT issues with that. It had absolutely no negative effect on the mains or dip beams. There are also LEDs in all tail/stop ligth, license plate, reversing and fog tail light. No problems, and with the low current draw, I guess the hydraulic brake switch hopefully will last forever. There will be no H4 LEDs in the headlamps, for MOT reasons. I fitted relays to the mains/dips, resulted in considerably light output.
Robbie the Norseman 2004 V6 Roadster Sherwood green
