0 members (), 363 guests, and 27 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Posting Desperado
Posting Desperado
GRAHAM DID YOU GET MY REPLY TO THAT WING ITS VANISHED FROM TALK MOG WHEN I PRESSED SUBMIT THE WING IS OFF SIDE
You can easily check if the lighter socket is permanently live, or switched via the ignition. Plug something into it (e.g. phone charger, sat nav) and turn the ignition on and off.
If live when ignition off (and it should be), you can charge through it. My 4/4 is almost permanently left connected to my CTEK 3600 smart charger.
The only issue for me was that Morgan had not connected up the lighter socket! Easily solved once I found the purple cable amongst the rats nest of wires laughingly called a "harness" apparently randomly crammed up behind the dash. But the supplied socket is very cheap and nasty, and doesn't make a good contact, so I swapped it for a marine grade socket (Sutars) - much better.
Nigel
50/50 choice John! Particularly as I was at work at the time smile
Will make a note on the relevant thread!
Cheers,
Trevor #70280 14/10/11 08:25 PM
The problem is that lighter sockets are not really designed to be power sockets. It may be better and safer to change to a DIN socket. See http://www.talkmorgan.com/ubbthreads.php/topics/54033/nputtick#Post54033 and the following comments.
