Posts837,275
Posts: 2,583 |
If you missed the live feed, or want to watch again, races at the DHF can be viewed at your leisure at www.doningtonhistoric.com
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Thanks, just the thing for a very wet weekend down here.
Posts: 2,583 |
Thanks, just the thing for a very wet weekend down here. It`s coming down in stair-rods here - so much so I`ve cancelled my daily run - so may revisit Donington this afternoon.
Posts: 3,690 Likes: 128
Posts: 3,690 Likes: 128 |
Phil: Do you by any chance open a brand new 5-litre tin of oil every time you top up your engine and leave the rest in the can untouched on a random shelf?  Thanks for the link, I watched it live last week from your previous post but it's worth another view. However (and I realise I risk coming across as a bit of an old curmudgeon here): you acknowledged my post last month that you had already created 5 of the existing 8 posts about this event and since then you've started 2 more!!  It's much easier to follow a discussion in a single place, rather than split into10 separate threads in different forum sections. Notice that in the menu bar above there is an Active Threads link, could I suggest you try using that to access the forum to see what topics are current and add to existing threads when possible? All the best.
Posts: 2,583 |
Thanks Ian - but I tend to find that many TMers only look at the newest topics section - and that after a few days threads are not often visited - but most likely I am wrong in this. By the way - does anyone want some 5 litre cans of oil with four litres left in each - they are cluttering up my garage.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I'll have one Phil, great for annoying the nimby next door when I have a garden bonfire
Thanks Ian - but I tend to find that many TMers only look at the newest topics section - and that after a few days threads are not often visited - but most likely I am wrong in this. You only have to look at the many long-running threads to see that's not true. So, have you driven your Morgan today?, as one example, has been going since 2014 with over 11,000 replies. I don't want to labour the point Phil, just trying to educate!
