5 members (Image, +8Rich, Graham, G4FUJ, RubyMog95, High Hamster), 332 guests, and 63 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 6 of 6 1 2 3 4 5 6
O
O
I may be a complete knucklehead but draining the box was essentially impossible with the NVH modification bolt-on. I could not get my wrench in there to loosen. Going to try pumping the oil out from the fill plug up top.
I believe I used a socket wrench and it worked fine with the NVH in place. Any other style wrench will not work. Be prepared for a mess.
A long 10mm spanner and a 10mm hex bar is ideal for dealing with the fill plug.
I use the hex bar from a set like this:
The drain plug is 24mm. I don't remember any particular problems accessing it so I guess something in my tool kit just fits!
Andy
