Evening Folks - need your collective help if I may please?
Was at Goodwood today for the excellent Brands Hatch Morgan event and we had our own dedicated group of 3-Wheelers with plenty of track time - all fabulous stuff. This was a 98dB day and I came prepared with those slip-on cans I posted the other week. They make a huge difference and on the normally notoriously angry Goodwood noise meter, measured a paltry 94dB at 3750rpm. Others with stock/drilled pipes were pushing 98-101dB depending which way the wind was blowing.... These slip-ons are just absorption type baffles, but reduce the pipe exit from 2" to 1". Performance slightly 'fluffy' at 4500+, but nothing too serious. Car felt lovely on track, handled as I wanted and was pulling 5,500rpm easily down the back straight -I ran out of gearing. I didn't hit the limiter at any point and the engine performed really well.
Drove away and all was well. Those that know the Goodwood-to-Petworth route will know that there is a long downhill section as the road drops down Duncton Hill towards the farms below. I went down the hill in 3rd on overrun, as there was slow traffic ahead. As I went back on the gas as we rounded the S-bends outside Seaford College, the engine stuttered but cleared as I accelerated away. This continued for the journey home.
Symptoms - anything more than say 20% throttle produces perfect running, powerful pull and everything is normal. But hold a very light throttle cruise and the RHS cylinder (viewed from driving seat) fluffs and misses and the engine runs on effectively 1.5 cylinders. Squeeze a little more gas pedal and all returns to normal. Idle is lumpy for sure, but it does idle tolerably.
Got home, removed plug and Lambda and both black as pitch. Very rich running evident and as my car has no CATs, very obviously rich, old-school exhaust smell. Cannot for the life of me think what might be wrong. Too much fuel clearly, but that makes no sense. Changed plug, cleaned Lambda - no difference whatsoever.
Maybe some hang-over from running those ever-so-slightly more restrictive slip-ons? I could understand a little 'adaptation' but the drive home was without the cans, so car back to where is was on the way there. If this was weak running, then I'd suspect a partially blocked injector, but way too rich on a very small throttle opening? Weird.
Thoughts folks? I've not plugged ProTune in as yet, but no Engine Light, so unlikely to find much to help in there. Great day, spoilt by an annoying glitch it seems. Thanks for help
![[Linked Image]](http://i.imgur.com/8Ta1vbu.jpg)
![[Linked Image]](http://i.imgur.com/egFCQBm.jpg)
![[Linked Image]](http://i.imgur.com/lkyti1t.jpg)
