5 members (2949olivier, Ncik P, deano, MATTMOG, JohnHarris), 200 guests, and 69 robots.
+8Rich 79
Topics49,871
Posts837,681
Rudolf
Page 9 of 10 1 2 7 8 9 10
I dont know
Are you going to not run mudguards? I am real curious to know if they would fit. Pirelli makes a nice tire.
Chris99 #574749 02/05/19 01:16 PM
Originally Posted By Chris99
Originally Posted By LightSpeed
Hey Dan, is there any practical advantage to going to more than 48 spokes if you are not racing?
Thanks for the info on the custom wheels. That loosening the fenders in order to remove a knock off wheel just eats at me.
i have my tyres fitted at MWS and they just deflate the tyre. No need to loosen or remove the mudguard (fender).
I have to do that to remove the rear tire on my 1978 GL1000
Rodger
2004 Plus 8 (wife's)
It makes sense that if a person needs to remove a tire/wheel then the tire is probably flat anyway, or the tire needs replacing so deflation is not a big deal.
the other half of it is, when I put in a new tire it has no pressure either so it fits easier. I then re-inflate it after it is on.
Rodger
rcmatt #574835 03/05/19 12:33 AM
That makes sense.
They were fieffée with moto cross tubes 4mm
I try them this week
first tests with Pirelli :
Lille - France
Plus Four 2024
As for the tires, what size are they and do they provide a soft ride?
As for the exhaust pipes, two flex joints AND a central mounting point tothe body for the pipe between the flexjoints! How did you do that?
Will the mudguards fit over the 110/90?
Yes - both stock steels and G56 carbon-kevlars.
