0 members (), 197 guests, and 33 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
#704272 22/05/21 07:17 PM
During normal driving I have no problems with the steering. No hint of vibration over a range of speeds. Very slight steering wheel play whilst stationery.
However, I clipped a sunken drain with the NSF wheel doing about 50mph and the subsequent vibration or wobble was quite alarming!! I eased off the accelerator, allowed the car to slow down and eventually at around 20mph all was back to normal. Driving thereafter was normal. Some days later ( and about 60 miles covered) and exactly the same thing happened.
Anyone point me in the right direction of what to check?
I had the same experience some time ago. Quite scary. Problem was wheel balance.
Hi Gary,
I would suspect that you lost a balance weight when you hit the pot hole and as MOR404 suggests it's a wheel balance problem.
I would suggest that you pop along to a tyre shop and have the n/s wheel balanced.
hope this helps
Rob...
Why is there only one monopolies commission??
Rob B.
Gary,
Which model of car. Also what year and mileage?
Surely if it was a dislodged wheel weight the wobble would manifest itself every time Gary went above a certain speed. Maybe 50ish.
Why would he get a period of no problem then a sudden return after about 60 miles?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Hi guys. I'm with Ivor Mog. Strange that another grid strike some days later caused exactly the same symptoms, but no issues between the 2 incidents. I'd expect losing a weight to manifest itself as vibration most of the time. The wobble was significant when it first happened. Caused me some concern.
Plus 4, 1993, 42k
Have you checked that the initial "pothole" incident didn't break the diagonal crosshead brace? Or the lower tie bar.
Bob
2009 Black Roadster
There's nothing obvious.
The diagonal tie rod was also in my thoughts. They usually break where the threads finish at the lower end where they are screwed into a lug that is then located onto the chassis. Not always obvious unless you look really close and give the rod a shake.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Diagonal tie rod? I'll have a look.
