9 members (TBM, deano, John V6, +8Rich, RedThree, Alistair, TeddyAds, cerealsurfer, MJF), 373 guests, and 55 robots.
+8Rich 92
Topics49,839
Posts837,301
Originally Posted by Gary Fairhurst
Diagonal tie rod? I'll have a look.
If unsure, check out go-mog workshop manual online: “Front Suspension” section, click on paragraph 12.03 headed “crossframe adjustment” and you will see a diagram in which they refer to it as a crossframe stay.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
+1 for the issue being a broken diagonal stay as shown below from GoMog article.
ETA: Note when car is jacked up to investigate the load removed from suspension may leave this stay in slight compression so a break may not be immediately obvious.
Put some axle stands near the outer edges of the lower cross head tubes and it will open the crack up slightly as the cross head flexes.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Thanks everyone. Great stuff for a relative novice. Will post when I find the reason.
jbk Offline
Have you checked that the damper blade is still bolted up as it should be Gary, easy to eliminate, worth a look
1993 T16 +4 Lancia Blue.
I have a much older +4 and experienced the same after crossing a particularly rough rail road track. The wobble was so violent, I thought I had a front wheel coming off. That was 5+ years and many miles ago. It has never happened again and I have no apparent damage. It was as though the shock absorber was overwhelmed by the violence of the impact and stopped working momentarily.
67 +4, 5 sp M3W, 3.7 Roadster(s), CX Plus 4
Front wheel wobble commonly known as the St Malvern`s dance on Morgans can be related to a number of issues. Later Morgans with wider wheels and thus more grip on the road surface seem devoid of the tendency to "dance." There are many theories relative to front suspension alignment in terms of rake and trail etc.etc.etc. Hopefully the link below might provide you with an insight, or indeed provide you with even more questions... (-:
Good luck.
https://www.gomog.com/BLAIR/tech/frontsuspension/wheelvibration.html
As others have said, the things to check are damper blades, shock absorbers and mountings, tie rods, kingpins and bushes, tyre balance, pressures and general condition including age.
I notice that my 4/4 is more prone to wobbling if the suspension needs greasing or the damper blades are poorly adjusted.
Black Rat
Black Rat
Brake reaction bars will help that, tightens up the front no end and cheap.
Keith
2013 narrow bodied + 4 Ruby.
I suggest you check if you have any play due to kingpin bushes wearing out. With steering wheel line front wheels straight ahead, grab tyre from top and shake in and out. Notice if there is any sideway play.
If yes it could also be the culprit.
