4 members (verysideways, Soleng, tommog, Ian Wegg), 335 guests, and 40 robots.
John V6 69
DaveW 66
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Just noticed a low water level in the header tank. Lost about 0,5 cm in 1000km. Now I discovered that the T-fitting, connecting the three hoses is leaking. You wont see anything on the garage floor. The drops remain on/in the chassis. See red dots in the middle of picture. If you put your finger under the T-fitting it gets wet. The screw of the middle clamp was quite loose. I tightened all the three, hoping not to crack the T-piece. I advise to check this periodically. Regards from Switzerland. Morgan Plus4 2019 12'000km.[Linked Image]IMG_3994 by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Try Simon at SiFab. He can supply you with metal T pieces that are much more robust. Mine were not leaking but I replaced them with the metal options
Alan
2009 Roadster 100 'Merlin'
Well worth replacing as suggested above.
BTW - for Roadster owners, there are two similar fittings. The one that is not shared with the +4 and 4/4 is even more fragile.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
I replaced mine the plastic cracks. Simon supplied it from memory.
2025 MG ZS EV aka Trigger
Where's the 2nd T-piece? I've just replaced the obvious one, tee-d off the hose from the header tank. Haven't spotted the other!
Nick
On the S1 there is one on the crankcase ventilation pipes from each cylinder bank. If it cracks air leaks cause a lean mixture. I got mine in brass off fleabay
X
X
Old fashioned carpart dealers have some „connectors“ made of copper or brass.
In my hometown it‘s „Bremsen Henrich“.
Or have a look or ask Mr. Google... messing-t stück 8mm
Greets René
2018 plus4 (sports green)
From memory brass is not good with some antifreezes. The crankcase T needs 2 one diameter & 1 another. I could only get it on fleabay
The steel "H" connector which acts as a heater by-pass when the heater valve is closed on my mid 80`s +8 was beginning to look a tad corroded. Apparently the Stainless replacement was created by Simon of this parish.... If stuck I could have messed around with copper T`s but the stainless is a rather neater job than I might have managed..
X
X
For the diameters: the piping must have a print for the specification of use and diameters.
Greets René
