7 members (John V6, How, DCH, MartinB60, IcePack, Luddite, TBM), 362 guests, and 42 robots.
+8Rich 92
Posts837,279
Page 8 of 16 1 2 6 7 8 9 10 15 16
Assuming that you've ordered enough parts to make a few spares, please can you add my name to the list of recipients. cheers
Andy
BearDee Offline OP
Hi Andy
I've ordered enough parts to build a couple of prototypes. I'll then fit one in my car having the old original one as a spare.
If all goes well after a reasonable trial time, I'll fund 50 units and happily sell individual units at cost to the community
I am also a taker for two.
Run a separate wire from the sender in the tank, very easy to do. Put a fuse splitter on a circuit of your choice, I might have used the horn circuit, there you have it.
Thanks for the info Lightspeed; I'll see if my capability is up to it !!
Johnny Vans
Brooklands Edition M3W
1935 F2
2021 Mini Electric
Hi BearDee
Just as an item of interest, I was cleaning car yesterday and switched on hazard lights. Ignition off. Petrol pump started and dash lit up. Was able to start and drive car with ignition still off!
Great option if you lose the keys!! Or want to misappropriate the vehicle!
Think I would be in the market for AMB device too
Originally Posted by P964
I switched on hazard lights. Ignition off. Petrol pump started and dash lit up. Was able to start and drive car with ignition still off!
scared
Andy
BearDee Offline OP
Hi
That sounds very strange, however it doesn't surprise me either.
I think trials will be completed by the end of the Summer and we can start to build at least 50-100 units, so watch this space. We'll be sure to let the community know when units are ready.
Hi BearDee
A "feature" of early cars😀
Red Leader drive
Jep Offline
Please put me on the list for one unit!
Jep
After a fuel pump failure I have just looked at the flasher relay which works only when it wants, the two electrical plugs are unsoldered from the pcb, the engine vibrations with the 132 cub even managed to trigger the steering wheel control during the period of engine break-in
I would give the result after having redone the welds.
