8 members (Trim, John07, nick w, Graham, G4FUJ, lord-richfield, ADMOG, Topline123, mph),
284
41
Topics48,364
Posts813,342
Members9,215
Posts: 7,941 Likes: 218
Posts: 7,941 Likes: 218 |
Have to say I'm horrified when I see those one metre plus breaker bars in use to tighten spinners. The torque they allow such to be tightened to is scary in the wrong hands. Having said that you may need one to undo spinners over tightened by same, fighting fire with fire!
I admit to owning a 600mm breaker bar but use and carry with me one of those pressed steel spinner tools, little over 400mm in length. A few heaves on that tightens and removes to what I regard as sensible torque.
Posts: 316 |
This is the best stuff for splines and spinners: ![[Linked Image]](https://tm-img.com/images/2021/06/05/IMG_2180.jpg)
2005 Roadster 3.0 S1 1960 MGA Roadster
Regards Aage
Posts: 5,110 Likes: 56
Black Rat Charter Member
Posts: 5,110 Likes: 56 |
I always use hand tight plus a quarter turn.
Posts: 150 |
I admit to owning a 600mm breaker bar but use and carry with me one of those pressed steel spinner tools, little over 400mm in length. A few heaves on that tightens and removes to what I regard as sensible torque. Just checked my Britool breaker bar. 58cm knuckle to very the end, 50cm ‘ish to where I would apply pressure. I am fairly lightweight so I feel this is okay. Watched the garage hammer my rears on then a few days later removed them for cleaning using the breaker. Expected a fight but they came off almost too easily! The front ones I had earlier tightened with the bar came off with a similar level of grunt as those the garage had hammered on. So I think I am happy enough with the breaker
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
I admit to owning a 600mm breaker bar but use and carry with me one of those pressed steel spinner tools, little over 400mm in length. A few heaves on that tightens and removes to what I regard as sensible torque. Would be someone near Cambridge?  I agree Richard you don't need much to get them tight.
Posts: 1,179 Likes: 17
Posts: 1,179 Likes: 17 |
Despite only lightly tightening (40lbs ish) I have to use a scaffolding pole extension to breaker bar & some heat to undo the centre nut. They self tighten over about 3 months. In my case removing the wheel roadside would be impossible.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
There's a difference between stainless and powder coated wires.
The powder coat grabs the nut. When I had black wires I had the same problem, that only heat and a lot of force would undo the nuts.
With stainless wires that has never happened.
Posts: 150 |
I admit to owning a 600mm breaker bar but use and carry with me one of those pressed steel spinner tools, little over 400mm in length. A few heaves on that tightens and removes to what I regard as sensible torque. Just checked my Britool breaker bar. 58cm knuckle to very the end, 50cm ‘ish to where I would apply pressure. I am fairly lightweight so I feel this is okay. Watched the garage hammer my rears on then a few days later removed them for cleaning using the breaker. Expected a fight but they came off almost too easily! The front ones I had earlier tightened with the bar came off with a similar level of grunt as those the garage had hammered on. So I think I am happy enough with the breaker I should have said that what I have described, above, is with stainless wheels.
Posts: 188 |
thanks gents, on the next rainy day the wheels will be off.
2004 Silver Roadster S1
Today I took off the passenger side front which for some reason is always the tightest. After less that 3 months it needed the full extension bar. I used to use the hammer method but on the road side it will need a lot of repeated umph.
