1 members (Saxonian),
261
73
Topics49,849
Posts837,424
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
I checked recently and on 7 July Morgan had Luggage racks - only in chrome - Australian out through version (11 in stock) - Standard clamp version (7 in stock)
Thank you, Black Adder. I'll see if I can get mine shipped.
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
I checked recently and on 7 July Morgan had Luggage racks - only in chrome - Australian BOLT through version (11 in stock) - Standard clamp version (7 in stock)
Australian BOLT through version - sorry Typo
Omne trium perfectum
I finally received my luggage rack from Morgan via my dealer. Question for those of you who have installed them. Since the brackets that clamp to the roll hoops are essentially made to fit a vertical bar, which the morgan doesn't have, how have you guys attached them? The new style is designed with removable pins so you can easily remove the rack. But the brackets need to be on a horizontal plane for this to happen. If you tighten the brackets on the slightly slanted rack, they natrually want to turn to follow the roll hoop. Did you try to ignore this tendancy and tighten them down anyway? Use 3M tape to keep them in place and keep from maring the hoop? Suggestions?
Thanks in advance.
Posts: 131 |
Thanks in advance. Any chance you have them installed correctly? They only fit ONE way or the angle is like, WTF?
'17 M3W (BRG) '03 Plus 8 35th Anniversary (BRG) '08 Ural Patrol (BRG) '21 Vespa 'Racing 60' (BRG)
Posts: 1,671 |
Use lamp truss brackets - They make it so easy to remove the rack
Michael, I think you are right, I had them installed at too high an angle on the roll hoop. I now see that there is only one way to install them. I've pulled it off and adjusted them on the bar and now they seem to set better. Thanks.
Posts: 131 |
Michael, I think you are right, I had them installed at too high an angle on the roll hoop. I now see that there is only one way to install them. I've pulled it off and adjusted them on the bar and now they seem to set better. Thanks. Yep, only ONE way! I made the same 'wtf' error. They're actually a beautiful, sophisticated piece of kit when installed correctly.
Posts: 637 |
Very un-Morgan like in that case! 🙃
