New
Topics48,365
Posts813,372
Members9,215
Posts: 2,222 Likes: 20
Posts: 2,222 Likes: 20 |
A 1 metre length breaker bar like this one Is good. I bought mine from Screwfix When fitting the wheels on the car, I just nip the spinners up until I feel slight resistance, only using just the first lower 2ft of the bar. I need the extra full length of the bar when it comes to undoing them though, due to self tightening. ![[Linked Image]](https://www.tm-img.com/images/2021/04/15/D58D7AB3-827C-451F-BDF5-DFE167082FA8.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/04/15/9B465F4E-750F-4C85-85EF-19911EB503D7.jpg)
Craig Jezz
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
A bit of Copaslip on the threads and around the groove in the back face of the nut that bites into the wheel centre helps
Posts: 1,211 Likes: 21
Posts: 1,211 Likes: 21 |
DIY tips of the day....... If you've a 20mm gap between your window and cill save silicone by taking a handful of stones off the drive and pushing them into the gap........ ![[Linked Image]](https://www.tm-img.com/images/2021/05/19/IMG_20210519_084713.jpg) Loose pieces of conti board, Formica and broken bits of moulding make great Packers to support a window cill!!!!!! ![[Linked Image]](https://www.tm-img.com/images/2021/05/19/IMG_20210519_084444.jpg) I've seen some botch jobs in my time but this is the worst I've seen for a while! worrying thing is the houses former owner who had the work done was an old lady, I dread to think how much she paid for this.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 1,384 Likes: 56
Posts: 1,384 Likes: 56 |
my pal has the ability to destroy most things. His latest triumph involved de-clogging his garden shredder using an iron bar with predictable bangs and explosions.
The shredder wheel now has a half inch gouge in every tooth and the cast aluminium slipper simply exploded into a thousand pieces.
I am proud to report that I managed to re-purpose an MGB leaf spring, round bar and square tubing and fashioned a new, much stronger, slipper and the shredder is now working again.
I wont mention the yards of Gaffa tape involved in repairing the casing as that was his handiwork!
Posts: 35,792 Likes: 473
Posts: 35,792 Likes: 473 |
Replaced the dual grill element in the NEFF built in double oven unit, quite painless really and as it is 16 years old now thought it might be a problem getting spares. This outfit are brilliant and fast an OE part for £71 and here the next day. They had a cheap option but why bother, do it once.. No connection other than a happy customer with brownie points in hand.
Posts: 6,829 Likes: 59
Posts: 6,829 Likes: 59 |
Had dealings with them and they are good.
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
Good to know. ours are 3 years old so fingers crossed will go on a bit longer
Posts: 4,491 Likes: 65
Posts: 4,491 Likes: 65 |
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Not a pretty scene, this was posted on here about 3 years ago and it makes you wince if you are a Morgan lover..
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Yes indeed. It also makes me wonder about stopping distances in Morgans. A moments inattention a few years ago and I nearly went into the back of someone whilst driving my Roadster. I slammed on the brakes and travelled along the road on full lockup for a very long distance... I fortunately stopped in time, but I was genuinely surprised at the distance travelled!
+8 4.8
