7 members (stumog, Simon, JohnHarris, Grumpy2, JoeSpeetjens, Gramrugby, Burgundymog),
356
61
Topics49,859
Posts837,504
Posts: 1,947 |
I need to remove the silencers & I'm struggling to separate the joint forward of the silencer. I took them off at 2 years old to drill the baffles & it was not very hard. Since then its been back to MMC for new chassis & 4 years on they dont want to come off, I have only managed to move RH one back about 3mm. I tried penetrating oil AC90. I'm thinking of applying heat from a hot air paint stripper to the joint with a wet rag wrapped round the pipe just forward of the joint. If that is not hot enough will use of a blow lamp leave the pipes blued?
Posts: 1,562 |
Have you tried a strap type oil filter remover tool to get extra turning force, as you wriggle it out ? I find getting it turning is the first sign it will withdraw
Posts: 1,947 |
I dont have a filter strap, a large screwdriver does that job.
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
I used a pair of strap wrenches, and slowly worked them off. There were a few minutes I thought they would not budge, but I saw slow movement and they eventually came. But mine had only been on a year…
2020 M3W
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
"Twist and shout". You want to avoid too much pulling straight back as you don't want to damage the headpipe or flex coupling. As noted above, twisting, and perhaps some spray lube, is your friend.
Upon re-assembly, a light smear of anti-seize can help the next dis-assembly. Bear in mind if you overdue it, the excess anti-seize will liquify and run out of the joint the first time the exhaust gets hot, so go sparingly. Messy, but no harm done.
Steve Late 2012 M3W
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
I spray penetrating lube into the joint and leave for a couple of days before removing seems to work as I've not had any issues, I too use anti-seize when reassembling.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I have had this problem when I took the engine out, like yours just on one side. I ended up opening the joint at the slots, then using the heat cool method with a blow lamp and eventually had to resort to a brass drift and big hammer.
When it went back on I used Neversieze on the joint to stop it happening again.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Ah - same problems I had a year ago. I too hammered and chiselled away, and sprayed copious WD40 into the joint, for 2 or 3 days … Dispairing in the end I bought 2 rubber strap wrenches (1 for the exhaust the other to counter the torque on the front section) to twist them loose. Each side then was off in 10 - 15 minutes! Naturally make sure the WD40 doesn’t get under the rubber strap. https://www.amazon.co.uk/Silverline-598531-Rubber-Wrenches-2-Piece/dp/B000O51BWW/I now have 2 old surplus exhausts, 1 with a conical end where I had been chiselling it!
Posts: 1,947 |
I need to get a pair of strap wrenches.
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
Or you could try a metal bar bolted to a U bolt, one each side of the join if there's room to get in
