7 members (flyfisher, IcePack, ChrisConvertible, Ian Wegg, Rog G, BLUE+4, MATTMOG),
247
34
Topics49,918
Posts838,263
Posts: 44 |
Posts: 1,005 Likes: 31
Posts: 1,005 Likes: 31 |
Sometimes I regret fitting the clock at that spot, as the clock’s light reflects in the sidescreen exactly in line of the outside mirror, this is disturbing when driving at night or in a tunnel.
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Sometimes I regret fitting the clock at that spot, as the clock’s light reflects in the sidescreen exactly in line of the outside mirror, this is disturbing when driving at night or in a tunnel. Bert, you don’t need a constant readout of the time. Fit a toggle switch into the feed to the clock panel light. You can switch it off in tunnels. Better still fit an air con outlet over the clock and you can direct the vents like they do with traffic lights. Or just close your eyes in tunnels. Other option is to drive faster you won’t need to look in the mirror
Craig Jezz
Craig, I love your creative thinking, placing louvre style shutters over the clock is very much in style, I am going to think about that. :-)
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
One tip..if you are going to use a hole saw it’s best to ‘score’ the dash surface first by using it in reverse in the drill. Less chance of the teeth digging in. Good tip... In the excitement of the project, it is easy to forget this step.
Posts: 44 |
Frightened and not confident bout removing dash- I there any other way to expose wiring for. Clock? Thanks
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Dash only needs to tilt backwards a few cms. so you can get hands in and see what is in the way. Removing dash is not only necessary to find wiring but also to make sure of where your drill/hole cutter is going to end up, to avoid accidentally chewing up wiring and also to fix the clock in place from behind. Sounds like you need to outsource the job?
Craig Jezz
Posts: 902 |
Dont be frightened. To move the dash back enough to cut the cable tie attaching the wiring loom isnt difficult. Simply remove the 3 screws securuing the dash and also the small screws attaching the plastic lower dash panel.
The hard bit is having the nerve to take a 60mm hole saw to your dash!
Rob
