0 members (),
323
82
Topics49,849
Posts837,424
MOG414_passengerFOOTREST&storage
When I got my Morgan, I noticed that it did not have anywhere to store say a camera, tools etc, under lock and key, if one needed to park the car and be away for some time. 'Googling' I found that a compartment was available to fit in the passenger side foot well that would also double as a footrest. But I thought it was too expensive so I looked around in my workshop and found an old tower type computer outer metal case. Took it apart and managed to fabricate the sides of the 'new' compartment complete with ventilation slots on one side. Front top, backside, bottom and front bottom were folded from a sheet of electroplated steel, that probably came from a scrapped upright refrigerator side. For the door/footrest I used 2.5mm aluminium plate, left over from my aircraft project. It was attached with a piano hinge. Countersunk pop rivets were used except at the back. No new holes were drilled in the firewall bulkhead since I picked up the same bolt holes that hold the bracket for the screen washer water bottle. After trial fitting, I sprayed the case in 2K silver paint, fitted a piece of non-slip carpeting inside and glued a rubber mat to the external surface of the footrest/door. A lock was also incorporated. It is quite unnoticeable for passers by. Total cost: under €20 plus did my bit at recycling;))
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Another nice piece of work there Reno. I had a mock up made and trial fitted but Mrs D didn't like it at her feet so i opted for the locking storage box on the luggage rack.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Excellent piece of work and at less than 10% of the cost of buying one.
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
Nice work! A footrest with louvres in a Morgan, wow!
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 28,898 Likes: 352
Posts: 28,898 Likes: 352 |
Very nice!
Posts: 96 |
Another nice piece of work there Reno. I had a mock up made and trial fitted but Mrs D didn't like it at her feet so i opted for the locking storage box on the luggage rack. If your better half is pretty tall, maybe she was right. Mrs P is approx 5’ 6” and she is ok with it. Actually she is better off since she can rest her feet on the slanting door. That is better and probably safer than having them flat on the floorboard. Thanks and have a nice weekend.
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Wow ! You are one skilled chap
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Bending metal so exactly  :
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
I used 2.5mm aluminium plate, left over from my aircraft project. Only on TalkMorgan would I expect that quote!
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 96 |
Bending metal so exactly  : It was all bent around a couple of hollow sections gripped in a metal vice...I do not have a folder unfortunately and only a handful of hand-tools in my workshop;(
