10 members (Grumpy2, RichardV6, howard, Jensen1960, Rex_tulips, Gerry Seale, IcePack, +8Rich, Mauli, brownbaker),
266
36
Topics48,362
Posts813,328
Members9,215
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
Looks great Nick worth all the effort.
Where did you get the wiper blades from.
Slowly going green
Posts: 2,027 Likes: 23
Posts: 2,027 Likes: 23 |
Are you able to get the windscreen wipers to actually rest/end sweep on the glass or do they "park" on the trim/body?
Mine park on the trim and it shreds the rubbers and drives me just a little bit nuts. The wipers (just) stay within the windscreen, its tight at both swept ends but worse at the scuttle area. It stays off the paint by about a mm, and took a little fettling to get right! Looks great Nick worth all the effort.
Where did you get the wiper blades from. Thanks John, I got them from MMC.
Aero 8 GTN #11
Well it is finally booked into the bodyshop to sort the little niggles.. should all be done by the end of the month!
Aero 8 GTN #11
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
Hopefully just in time for the sun to return!
Cheers, Paul
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Nick, you have what is, in my view, the most beautiful early Aero 8 I've ever seen. WELL DONE... now all you have to do is enjoy driving it!
Hopefully just in time for the sun to return! Fingers crossed! Nick, you have what is, in my view, the most beautiful early Aero 8 I've ever seen. WELL DONE... now all you have to do is enjoy driving it! Thanks Peter  I really must make an effort to drive it more!
Aero 8 GTN #11
A bit of an update, at the bodyshop finally to sort the few niggles. A few pics from one of the workshops where the car has been stripped down, quite interesting to see the chassis and inner workings. ![[Linked Image]](https://i.imgur.com/NV0f0Ru.jpg) ![[Linked Image]](https://i.imgur.com/IjgBuDt.jpg) ![[Linked Image]](https://i.imgur.com/nxElzMZ.jpg) Looks rather rat-rod at the moment! Once the paintwork is sorted, I have new leather beading, new lights, bolts, nuts, gaskets and all sorts to go back on - so should look nice and fresh.
Aero 8 GTN #11
Posts: 1,415 |
Now's the time to check the front wishbones for cracks, and deal with any loose ball joints. Its so much easier without the wings on
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 2,030 Likes: 10
Sir S1'a'lot Talk Morgan Expert
Posts: 2,030 Likes: 10 |
Yours looks a lot cleaner than mine underneath.
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Now's the time to check the front wishbones for cracks, and deal with any loose ball joints. Its so much easier without the wings on Do they crack anywhere in particular? I will have a look, but in theory they should be ok - I had all the wishbones checked not long ago  Yours looks a lot cleaner than mine underneath. Best get out the ol polishing rag and join me for a day when the tonneau is sorted
Aero 8 GTN #11
