0 members (), 323 guests, and 91 robots.
+8Rich 78
Topics49,872
Posts837,705
#708885 06/07/21 01:43 PM
BLUE+4 Offline OP
Good afternoon all,
Having had a new radiator fitted by BHM ( and what a great job they did ) I decided to fit a grill mesh for added protection. All went well after a bit of fettling.
Having pushed the cowl tabs back to accomodate the mesh I now find that the grill is a bit loose. With the new radiator in place it seems impossible to access the tabs from under the bonet to secure the grill enough to prevent rattles.
Any ideas on how to achieve this would be great.
Roll on July 19th.
Rob....
Why is there only one monopolies commission??
Rob B.
BLUE+4 #708887 06/07/21 01:57 PM
I would use a neoprene fix!
DaveW #708889 06/07/21 02:05 PM
BLUE+4 Offline OP
Hi Dave,
that is what I will do if no other ingenious method of reaching the tabs is put forward.
Thanks for your help.......
Rob..
Rob B.
BLUE+4 #708971 06/07/21 09:30 PM
I would be tempted to check the bottom of grill and mesh are secured properly at the bottom with the two screws with two rubbers on each between number plate box and grill. Also that they are tightened with the grill/mesh assembly pushed upwards into securing slot inside cowl.
BLUE+4 #708973 06/07/21 09:37 PM
X
X
The mesh is upside only hooked in. The main fixing is downside with the screws of the grille and the numberplatebox.
If it‘s ratteling, it‘s allways fixed downside with the screws. So is it wrong upside? Than the the hooks need a little adjusting.
Have a look here: http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/679412/Searchpage/1/Main/41650/Words/%2BMesh/Search/true/re-grille-who-fit-a-mesh#Post679412
Greets René
2018 plus4 (sports green)
BLUE+4 #708977 06/07/21 10:32 PM
Having pushed the cowl tabs back now push them forward until you get a tight fit doh rofl
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
BLUE+4 #708982 07/07/21 05:30 AM
Bruce, from the OP's original comment:
Originally Posted by BLUE+4
With the new radiator in place it seems impossible to access the tabs from under the bonnet to secure the grill enough to prevent rattles.
Rob....
Rob, I think you'll have to take grille etc. off again and close up the gap a little, then probably apply some of Dave W's fix. At least with neoprene it will stop any rattles!
[/quote]Rob, I think you'll have to take grille etc. off again and close up the gap a little, [/quote]
Graham, that's exactly what I meant shouldn't be too difficult.
Bruce
2013 M3W (Olga)
britmog #709057 07/07/21 06:25 PM
thumbs thumbs
DaveW #709066 07/07/21 07:26 PM
HJF Offline
Funnily enough I have taken my grill off today to do a few bits and bobs. Interestingly, three self adhesive neoprene pieces are exactly how Morgan have done it at the Factory (late 2018 4/4).
