Topics49,846
Posts837,376
Posts: 82 |
What to do ? Where is the relay situated ? Morgan plus 4 2008 gr tom tkx
Posts: 2,086 Likes: 70
Posts: 2,086 Likes: 70 |
First of all, check the connection plug to the wiper motor to make sure it has not worked loose.Relays are hidden behind the dashboard.
Posts: 82 |
Wipers are working in slow and fast speed ! Only in intermitted stand they are jerking 😀moving and stopping randonly Gr tom
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Your relay bank may be directly above the steering column under the dash. The big one is wiper delay.
Posts: 82 |
Solved ! Connector under hood was loose gr tom
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Its very interesting to note that the mechanical swith on the wiper motor itself where your connector plugs in does fill with water being under the bonnet and corrodes....so beware... DSC_1344 by Robert & Ali Davies, on Flickr DSC_1279 by Robert & Ali Davies, on Flickr DSC_1278 by Robert & Ali Davies, on Flickr
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
I wonder if a couple of tiny holes drilled into the plastic socket on the motor would stop water collecting & corroding the pins
Posts: 30 Likes: 1
Posts: 30 Likes: 1 |
Maybe a better solution would be to pack it with a dialectic grease.
Ron Davis 1986 +8 "Flapper" CanTab #1
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Well that would definitely keep the two parts of the plug talking to each other! 🙂 ..... sorry, couldn't resist it  K
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
My wipers gave up after the last heavy rain. I had them set on intermittent when the rain ended. Suddenly it did 2 wipes and stopped completely afterwards - and did not move since. I'm booked for the annual service this week so I hope it gets fixed.
