8 members (PaulV, Alan Culpitt, Saxonian, Davetherave, Scrambledsignals, Black Adder, sewin, TBM), 100 guests, and 29 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,261
Smed., Spanner Juggler
Page 2 of 5 1 2 3 4 5
SteveT #707886 25/06/21 09:15 AM
Thank to all
Best Regards
Gilberto #707923 25/06/21 03:36 PM
Sometimes I regret fitting the clock at that spot, as the clock’s light reflects in the sidescreen exactly in line of the outside mirror, this is disturbing when driving at night or in a tunnel.
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
BertR #707945 25/06/21 07:14 PM
Bert, you don’t need a constant readout of the time. Fit a toggle switch into the feed to the clock panel light. You can switch it off in tunnels.
Better still fit an air con outlet over the clock and you can direct the vents like they do with traffic lights. Or just close your eyes in tunnels.
Other option is to drive faster you won’t need to look in the mirror thumbs
Craig Jezz
Gilberto #707951 25/06/21 09:55 PM
Craig,
I love your creative thinking, placing louvre style shutters over the clock is very much in style, I am going to think about that. :-)
2009 Roadster
1983 4/4 4str
Craig Jezz #707954 25/06/21 10:40 PM
Loverly work....
SteveT #707958 25/06/21 10:47 PM
Originally Posted by SteveT
One tip..if you are going to use a hole saw it’s best to ‘score’ the dash surface first by using it in reverse in the drill. Less chance of the teeth digging in.
Good tip...
In the excitement of the project, it is easy to forget this step.
Gilberto #707999 26/06/21 03:34 PM
Frightened and not confident bout removing dash- I there any other way to expose wiring for. Clock?
Thanks
Gilberto #708001 26/06/21 03:47 PM
Dash only needs to tilt backwards a few cms. so you can get hands in and see what is in the way. Removing dash is not only necessary to find wiring but also to make sure of where your drill/hole cutter is going to end up, to avoid accidentally chewing up wiring and also to fix the clock in place from behind.
Sounds like you need to outsource the job?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Gilberto #708002 26/06/21 04:19 PM
I did just as Deejay describes, few more pics here might help ?
Craig Jezz
Gilberto #708010 26/06/21 05:38 PM
Dont be frightened. To move the dash back enough to cut the cable tie attaching the wiring loom isnt difficult. Simply remove the 3 screws securuing the dash and also the small screws attaching the plastic lower dash panel.
The hard bit is having the nerve to take a 60mm hole saw to your dash!
Rob
