2 members (John Winn, Alan Patterson), 180 guests, and 52 robots.
Topics49,846
Posts837,382
tom+4 Offline OP
What to do ? Where is the relay situated ? Morgan plus 4 2008 gr tom tkx
First of all, check the connection plug to the wiper motor to make sure it has not worked loose.Relays are hidden behind the dashboard.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
tom+4 Offline OP
Wipers are working in slow and fast speed ! Only in intermitted stand they are jerking 😀moving and stopping randonly
Gr tom
Your relay bank may be directly above the steering column under the dash. The big one is wiper delay.
tom+4 Offline OP
Solved ! Connector under hood was loose gr tom
Its very interesting to note that the mechanical swith on the wiper motor itself where your connector plugs in does fill with water being under the bonnet and corrodes....so beware...
[Linked Image]DSC_1344 by Robert & Ali Davies, on Flickr
[Linked Image]DSC_1279 by Robert & Ali Davies, on Flickr
[Linked Image]DSC_1278 by Robert & Ali Davies, on Flickr
Triumph Herald 1969 13/60
Morris 1970
I wonder if a couple of tiny holes drilled into the plastic socket on the motor would stop water collecting & corroding the pins
Maybe a better solution would be to pack it with a dialectic grease.
Ron Davis
1986 +8 "Flapper"
CanTab #1
Ron Davis
1986 +8 "Flapper"
CanTab #1
Well that would definitely keep the two parts of the plug talking to each other! 🙂 ..... sorry, couldn't resist it hide
My wipers gave up after the last heavy rain.
I had them set on intermittent when the rain ended. Suddenly it did 2 wipes and stopped completely afterwards - and did not move since.
I'm booked for the annual service this week so I hope it gets fixed.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
