2 members (mph, +8Rich),
367
90
Topics49,848
Posts837,402
Posts: 77 Likes: 3
Posts: 77 Likes: 3 |
"...the slots in the cover from manufacture still have the spacer washers fitted" --> so the ventilation seems still not enough with this small slots in the cover. Seems the CNC milling solution from the italian producer could be a nice way to solve this problem.
Eddy
built not bought - hustled not handed - earned not given - rare not average
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I am sure the CNC milled cover will solve the problem but the washers are only a few pence and work as well. Any ventilation improvement will be a bonus, I doubt you can have too much.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I dont like the spacers in between the motor housing and the cam cover because of air and rain water.
i ran the spacer solution for over 25,000 miles with no ill effects. This included torrential rain and deep puddles/fords. Simple, cheap and effective.
Red Leader
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
The belt debris is normal, as Mark says. S&S describe it as "snake skin" and it is the release agent from belt manufacture. There is also a cutout at the base of the cam cover that has been there since the start, probably to let the crank seal oil leakage out. I like the machined spacers on the later covers, I just super glue the washers in place to make things easier.
There does seem to have been a bad batch of belts about and they have shown signs of cracking after just a few thousand miles, well worth checking them regularly. In theory the belt life is 3 years or 30,000 miles (with the vented cover) but "on condition" seems sensible. It is a "safe" engine as the valves and pistons don't try and occupy the same space if the cam belt fails, always nice to know.
Is that right, Planenut? This is the first I have heard of a 3 year replacement advisory. I thought it was just by mileage. I better get mine replaced if that is true.
Aka Joejoe
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Planenut has a good idea with the super gluing the spacers in place, makes the entire removal and replacement of the cover much easier.
The belts do shed a bit and keeping an eye on them is another good idea, and the main reason I put a clear cover on mine.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
The belts do shed a bit and keeping an eye on them is another good idea, and the main reason I put a clear cover on mine. These transparent covers do look nice to me! I see 3 including the Italian company mentioned in this thread (but didnt check the alternative parts list...) plus I think Krazy Horse had a vented non-transparent option? USA - Morgan Custom (special order) - https://www.morgancustom.net/USA - Combat Motors (special request it seems) - https://www.combatmotors.com/online-shop IT - Given Motodesign - https://www.given.it/en/prodotto/carter-distribuzione-x-wedge-ss-e-crs-duu/
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
Omne trium perfectum
I have not seen the 30,000 miles or 3 year cam belt life written down anywhere but was told that is what it is by a Morgan workshop person after doing the cover venting and getting the cam chest upgrade done, FOC at that time. I still think that "on condition" is a sensible way of doing it, I check my cam belt condition every Winter service.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Ventilation requires airflow so the combination of the front vents and spacers provides such flow
That Given Motodesign air cleaner assembly is interesting. I think I saw one that was totally clear somewhere.
