Posts837,277
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 1,415 |
Then is should fold flat, gangster style…
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Update. After a bit of tugging and pulling I now have the hood sitting folded with the rear glass vertical allowing the frames to sit low as it should do.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- glad you have got it sorted Lee  I guess it was just the 'newness' of the material and getting it all to bed down to a sufficiently low level. I'm sure you are aware (from previous ownership) but be careful not to damage the leading edge Corners when the hood is folded and tucked under. I have a couple of bits of neoprene on the tops of the inner wheel arches to cushion the hood when folded. James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 12 |
Hi all ,
Any pics of the roof Fully folded to Check mine?
Regards
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
Mine is the original S1 roof as well but no matter how I do it the window is always on show but is horizontal. Is it possible to get the hood folded with no window on show? ![[Linked Image]](https://tm-img.com/images/2021/07/26/6B38D4B5-A358-48A1-AA64-F21E45DD6A0F.jpg)
Yes. This is my mates. You need to place the base of the window on top of the rear bulkhead rail and tilt the glass down ![[Linked Image]](https://tm-img.com/images/2021/07/26/5F0B4C86-31A7-43BD-AF9C-1FB79AC61B86.jpg) ![[Linked Image]](https://tm-img.com/images/2021/07/26/4198E703-95A5-4AA5-8E0B-AE42DD0D95CC.jpg)
- glad you have got it sorted Lee  I guess it was just the 'newness' of the material and getting it all to bed down to a sufficiently low level. I'm sure you are aware (from previous ownership) but be careful not to damage the leading edge Corners when the hood is folded and tucked under. I have a couple of bits of neoprene on the tops of the inner wheel arches to cushion the hood when folded. James Yes exactly. It’s why my hood needed replacing and the reason the one above needs doing. Top tip.
My problem now is that my newly made tonneau or hood bag is too big
Posts: 12 |
My car is similar , why ont selling your "too big " tonneau cover ?😁
