0 members (), 365 guests, and 43 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
#711564 26/07/21 10:58 PM
bobc Offline OP
Hi I have a Morgan 2002 +8. Could someone help me find the fuse box. Everything I have found says it is on the passenger side against the firewall. I cannot find t there. Unless I am blind(ha ha).
I would appreciate any help. Thank You
bobc #711566 27/07/21 04:21 AM
In 2004 there are two. One is on the bulkhead, offside under the bonnet. The other is centrally mounted under the dash.
A lot can change in two years though!
bobc #711574 27/07/21 07:11 AM
My 1999 car has the fuse box in a central location under the dashboard , it is over the transmission tunnel . You have to access it by lying upside down in either footwell.
I look in envy at more modern Morgans where all the fuses/electronic modules are located in one or two boxes on top of the bulkhead , easily accessible.
Andy G
1999 +8 , Indigo Blue.
bobc #711578 27/07/21 07:40 AM
And it would have been so easy to design the loom to accommodate such doh
MOG 615 #711594 27/07/21 10:02 AM
I know what you mean Andy, I’d only had my Plus 8 a short while when driving home from the Goodwood Revival I switched the headlights on and everything went black. Trying to find the right fuse, upside down, in the dark was not a lot of fun. They’re also pretty difficult to get out with your fingers. Turned out that the previous owner had used the wrong amp. fuse.
Steve L.
1996 Plus 8
N22 MOG
Steve +8 #711595 27/07/21 10:33 AM
Yup, mine is in the same place, but at least you don't have to stand in the rain with the bonnet up like the morderns do grin2
Ours just demonstrate the availability of chimney boys still being around at the design period...
2009 4/4 Henrietta
1993 Connaught Green +8 prev
bobc #711598 27/07/21 10:47 AM
Andy, that seems par for the course in terms of Morgan electrics, though my mid 80`s fuse box like many older Morgans is mounted on the bulkhead in the engine bay easy access even if some of the wiring is suspect. When trying to help Lorne with a few EFI issues on his +8, I think he discovered either a fuse or a large "pudding" joint hidden within the loom. I also remember a fuse being hidden in the loom of my old Mini many years ago, so Morgan were/are not alone in creating wiring mysteries and challenges...
Richard, assuming it is raining, it would be interesting to witness you trying to contort yourself to replace a fuse in your Morgan without getting wet... laugh2
bobc #711601 27/07/21 10:55 AM
Yes the old lumbago position for older cars with often the fuse box reversed vs the diagram.
2025 MG ZS EV aka Trigger
bobc #711604 27/07/21 11:02 AM
Diagram John...!!! Jeez that would be a luxury indeed... laugh2
Luddite #711605 27/07/21 11:06 AM
My tongue firmly in my cheek at the time George laugh2 At 6' it would certainly be wet legs and feet..
2009 4/4 Henrietta
