7 members (Paul F, Julian BB, Doug J, MartinB60, GrumpyPa, RedThree, BobtheTrain),
328
SORN
New
Topics48,370
Posts813,483
Members9,215
Posts: 1 |
Hi I have a Morgan 2002 +8. Could someone help me find the fuse box. Everything I have found says it is on the passenger side against the firewall. I cannot find t there. Unless I am blind(ha ha). I would appreciate any help. Thank You
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
In 2004 there are two. One is on the bulkhead, offside under the bonnet. The other is centrally mounted under the dash.
A lot can change in two years though!
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
My 1999 car has the fuse box in a central location under the dashboard , it is over the transmission tunnel . You have to access it by lying upside down in either footwell.
I look in envy at more modern Morgans where all the fuses/electronic modules are located in one or two boxes on top of the bulkhead , easily accessible.
Posts: 7,946 Likes: 218
Posts: 7,946 Likes: 218 |
And it would have been so easy to design the loom to accommodate such
Posts: 1,560 Likes: 7
Posts: 1,560 Likes: 7 |
I look in envy at more modern Morgans where all the fuses/electronic modules are located in one or two boxes on top of the bulkhead , easily accessible. I know what you mean Andy, I’d only had my Plus 8 a short while when driving home from the Goodwood Revival I switched the headlights on and everything went black. Trying to find the right fuse, upside down, in the dark was not a lot of fun. They’re also pretty difficult to get out with your fingers. Turned out that the previous owner had used the wrong amp. fuse.
Steve L.
1996 Plus 8 N22 MOG
Posts: 35,800 Likes: 474
Posts: 35,800 Likes: 474 |
Yup, mine is in the same place, but at least you don't have to stand in the rain with the bonnet up like the morderns do  Ours just demonstrate the availability of chimney boys still being around at the design period...
Posts: 4,615 Likes: 194
Posts: 4,615 Likes: 194 |
Andy, that seems par for the course in terms of Morgan electrics, though my mid 80`s fuse box like many older Morgans is mounted on the bulkhead in the engine bay easy access even if some of the wiring is suspect. When trying to help Lorne with a few EFI issues on his +8, I think he discovered either a fuse or a large "pudding" joint hidden within the loom. I also remember a fuse being hidden in the loom of my old Mini many years ago, so Morgan were/are not alone in creating wiring mysteries and challenges... Richard, assuming it is raining, it would be interesting to witness you trying to contort yourself to replace a fuse in your Morgan without getting wet...
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
Yes the old lumbago position for older cars with often the fuse box reversed vs the diagram.
Diagram John...!!! Jeez that would be a luxury indeed...
Richard, assuming it is raining, it would be interesting to witness you trying to contort yourself to replace a fuse in your Morgan without getting wet...  My tongue firmly in my cheek at the time George  At 6' it would certainly be wet legs and feet..
