3 members (Bishmog, +8Rich, BobtheTrain), 287 guests, and 40 robots.
John V6 68
DaveW 64
+8Rich 61
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,074
Captain Morgan, IRWIN
Page 1 of 4 1 2 3 4
MGDave Offline OP
My brake lights stay on intermittently, I give the switch a gentle tap then light goes out.
Does anyone have a part # please?
I believe these switches aren’t very reliable, as an alternative has anyone tried mounting a micro switch off the brake pedal?
Dave
98 +8 Corsa Red
74 MGB Red
The alternative is a relay to keep the higher power off the switch. I think they area BL part.
Details here on the part number etc Brakes
2025 MG ZS EV aka Trigger
I put a microswitch on my brake pedal in 2009 (I think) Dave and it's been totally reliable. I'll see if I can find the post.
Sadly that post was consumed by the debacle around Photobucket. But I mounted a relay on the crosshead, near the switch, which on my Roadster is offside chassis mounted.
The microswitch came from Maplins and I mounted that to a simple fabricated L bracket.
The mini-loom was piggy backed onto the existing switch terminals, so nothing was changed, allowing reversion to standard if necessary. The wires run through the bulkhead using the existing loom hole.
Don't bother sourcing a new hydraulic switch, because the quality is such that it will fail again at some point.
Retrieved image of piggy back on switch.....................
Retrieved image of relay mounting..................
Here is the part you requested Dave.
Slaving a relay will remove the current factor from the hydraulic switch as John suggests, this makes them far less prone to failure.
I have never had a failure on either of my Plus 8's in about 50,000mls and 11 years to put things in perspective for you.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Minés a similar age and mileage and I’m on my 4th switch, c’est la vie
Mike H
Bourgogne Franche Comté
Part of the problems seems to stem from the draw created by the additional brake light. I fitted a new switch and replaced the brake lights with LEDs. everything seems hunky dory now and for the past five or six years
Series 1 Roadster - the original Plus 6!
Why not fit LED brake light bulbs, problem solved and no need for a relay.
David Byrne
Mine still failed even with leds. I did a flying change which worked
Part of the problem is the poor quality of OE replacements, that's why +8 Richard's originals are still working
Page 1 of 4 1 2 3 4
