7 members (CooperMan, Montegue, JohnHarris, Steve Simmonds, Mike D, yrr13, TeddyAds), 183 guests, and 23 robots.
+8Rich 91
John V6 49
Posts837,982
#713021 06/08/21 03:38 PM
Black Rat
Black Rat
I have just purchased one of Lionels 2 eared spinner spanners cracking piece of kit, what length breaker bar do you recommend.
Keith
2013 narrow bodied + 4 Ruby.
Burgundymog #713023 06/08/21 03:42 PM
I have 3/4m but that is slightly too short. 1 to 1/2m might be better. I use also a mulfab spanner bolted to an old roof rack bar & that is over 2m. My front passenger side nut needs the longer bar.
But my wheels are painted & the paint I am told adds to the stiction.
Burgundymog #713031 06/08/21 04:21 PM
I bought a Sealey 600mm 1/2 share drive which works fine for me.
I almost forgot to mention that it fits under the drivers seat as it is not too long.
Burgundymog #713033 06/08/21 04:30 PM
Oddly it is only the RHS passenger that needs the bigger bar. Hawki's car is the same. I had thought it was just the first time I tried to remove the wheel but when I checked when Lionel's socket arrived it was the same.
Burgundymog #713069 06/08/21 08:02 PM
I'd be a bit concerned about using too longer breaker bar as it could allow excessive torque. Although I use an MG style pressed steel tool of similar length my 600mm breaker bar would work fine allowing a couple of good nudges to ensure adequate spinner tightness.
RichardV6 #713070 06/08/21 08:05 PM
It's the releasing not the tightening that the bar is needed for and to which John's comments applied I think..
I tighten my centrelocks with a 2' bar and release with an 8' bar attached.
Burgundymog #713076 06/08/21 08:19 PM
Correct taking them off. Doing up i use the mulfab tool on its own and hand tight based on it what 18 inch length
