12 members (Davetherave, MATTMOG, Vansrv6, JohnHarris, deano, AlyMatt, Image, 2949olivier, Hamwich, Cerberas, James B W, Sir Percival),
240
71
Topics49,871
Posts837,682
Posts: 172 |
The throttle cable on my 1600cc Fiat engined 4/4 looks rather home made (but is working ok for now). Did these cars use a cable from something mass produced (Ford?) or is this a bespoke Morgan part? Thanks
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Its probably the original!
Its highly likely to be a bespoke Morgan part due to the peculiar Morgan accelerator pedal
If you fancy making a new one up, Venhill amongst others can provide the materials
Arwyn
Posts: 516 Likes: 58
Posts: 516 Likes: 58 |
Jack, you could try car builder solutions.
David Byrne
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
As stated the pedal end is the important bit. When I had throttle bodies they adapted the original cable at the throttle end (as opposed to pedal end) and I decided to buy a spare cable from Morgan as nothing else would fit.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
