0 members (),
299
Posts837,277
Posts: 829 Likes: 22
Posts: 829 Likes: 22 |
1980 +8 Blue And a few others ---------------- Stephen
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Do you need LED Cibies as well as the LED headlights? It must be like daylight out in front.
I know you need to pick out deer and moose on the dark forest roads in winter , so I guess you need all the firepower you can get.
Posts: 107 |
Thanks again...
The front spoiler design/idea popped up since I bought the factory "sport spoiler" but the fit and alignment was soo bad. It was gaps of 7-8 mm on each side and there was no way to fix that unless you started to cut the spoiler in bits......that´s when the idea of the two extra bits between the spoiler and car came up. I think it came out good, almost like an old alfa Romeo style grill....
The LED Cibies are just there to melt any speed cameras coming my way....:-)
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
I would be a little concerned of ground clearance now with that spoiler. If you go for the SSL RS front suspension upgrade there is an option to place the included 20mm spacer above stub axle to raise front by same amount though.
Posts: 107 |
Thanks for your input Richard.
I will have the ride height in mind when changing to the SSL RS front suspension....
Cheers/ David
Posts: 987 Likes: 110
Posts: 987 Likes: 110 |
Very nice work! Great car! With this colour it looks a bit french. Reminds me a bit to cars like the Peugeot Darl´mat. ![[Linked Image]](https://imgr1.auto-motor-und-sport.de/Peugeot-302-Darl-mat-169Gallery-b7961087-335971.jpg)
2003 Morgan 4/4 2-seater
Posts: 18 |
Beautiful car! Well done! I like the spoiler and the brooklands.
Everyone tells me, there is no simple solution for brooklands on the Roadster. There is a screw behind the dashboard. Are you sure, the original windscreen is still kept in place without that one?
Posts: 107 |
Thank You Stonehagen!
I have seen several similar solutions on other Morgans and I do not think the roadster is very different from other models. But I cannot guarantee anything until I have tested it further, so I guess that we will find out. What I can say is that I had help by a custom car builder that builds cars from scratch and if he thinks this solution will work I trust him....But again not proven yet!
Posts: 107 |
Now I have had the Graphics/ Gulf livery done.....I like it but maybe it is only me? The purists will probably throw rotten tomatoes my way.....:-) ![[Linked Image]](https://www.tm-img.com/images/2021/09/20/IMG_3358.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/09/20/IMG_3361.jpg)
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
She looks lovely, track ready too  The top louvres left blue adds to the effect.
