13 members (Graham, G4FUJ, JamesS, DCH, MartO, Joske Vermeule, TeddyAds, sewin, cerealsurfer, High Hamster, BLUE+4, Alistair, BobtheTrain, Image),
308
61
Topics49,860
Posts837,520
Posts: 463 |
I have a Odyssey 925 battery it’s been in the car for 7 years and still going strong, I usually connect to the Ctek charger once a month. No problems so far.
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Isn't the idea of the Ctek charger/conditioner that it stays connected all the time while the car is "winterised" or otherwise not being used ? (with the charger's brain figuring out when to come into operation). Since buying my Ctek that's how I have used it, mindful of the instructions in my (Roadster) manual which states: "If the vehicle is left standing for more than 1 week then it is advised that a battery conditioner is used to maintain the battery correctly". So which bits of the car's circuitry cause the battery to run down ? As far as I can tell there's just the clock and the blinking red light on the dash. On another car I use a similar charger and for the past 6 winters I have hooked it up to a standard domestic time switch which activates it for 3 hours each night -- the battery is still absolutely fine and presently shows 14.5 volts (which I don't quite understand, as it is a 12 volt battery). ![[Linked Image]](https://www.tm-img.com/images/2021/11/03/Charger-3-Nov-2021.md.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Each cell in a lead acid battery is actually 2.2V (total 13.8V). When fully charged this is slightly higher.
Well that's a comfort; so I'm not slowly frying the battery.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
It had to happen... Tarka has fallen to COVID... well, the battery has.
Since the summer of 2019 Tarka has not had proper use and the battery has died, due I think to many short runs and sitting in the garage... Using a Battery Recovery mode on the charger it will charge to 12.2v but only at 80% and is down to 10v within 12 hours. I think we have a dead cell, or sulfation, or both.
I've ordered a Banner Starting Bull Car Battery (55519) from Tayna, should be here by Wednesday.
The weather looks good.
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
I use a Yuasa YBX5075 which has a higher CCA rating than the OEM battery and is typically around £60-£65 delivered.
Cheers, Paul
Posts: 535 Likes: 1
Oh and as I said earlier have my cars permanently connected to a C-tek conditioner at all times. Even the Range Rover which it outside on the driveway I have c-tek extention lead which I connect it to every night so the battery is always at it's optimum.
Cheers, Paul
Posts: 688 |
Mine sits on the Ctek on a timer which runs for a few hours a day. Cut out is switched to off. Good for 5 years so far.
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 5,442 Likes: 468
Posts: 5,442 Likes: 468 |
I am no expert but have gained a little knowledge on Batteries of late.. Modern AGM batteries differ from old style wet lead acid batteries in both their ability to hold charge, their normal terminal voltages, expected lifespan, and of course costs. An AGM battery thus may best be charged using a charger designed for that specific type of battery, given the different voltage /charging expectations..? Apparently a replacement battery for a P car can cost circa £500 to be fitted and coded to the vehicle... Coding is a must on the P car given the advanced battery monitoring and charge regulation systems. ALSO in the case of a P car it is advised NEVER to connect a charger across the battery terminals, there is a remote earthing/neg point to be used along with the battery +/positive for such situations. Apparently if a charger or jump start kit is connected directly to across the battery there is a chance of damage to the battery monitoring systems... I have no idea if Morgan use any such system. My old +8 does not..(-: The life expectancy of an AGM can be from 6-15 years... if treated well, i,e. not allowed to go flat or be overcharged on a regular basis..? I guess much depends on your use of the vehicle and how much time it spends being laid-up and whether it is on a CTEK or not. My AGM was too flat to start my car after sitting for 8 days not connected to a charger, the car having had a run of a couple of hundred miles which would have left it in a fully charged state prior to being garaged..! It now is permanently connected to a CTEK charger/conditioner specifically designed for use on an AGM battery I suspect if connected to a CTEK permanently when not in daily use, an AGM battery can soldier on for many a year, though only when left off charge for a period of time will you be likely to find out whether or not your battery has lost a degree of capacity to hold enough of a charge to fire up the engine when you need it to..! Thinking a weekend stay at a hotel, or left in an airport car park. Apparently in a P car a new battery is expected to still fire up the engine after 6-8 weeks off charge... I think much of that capacity is down to the level of sophistication in the battery monitoring system whereby the system apparently can go into a sleep mode, and further to that a deep sleep mode after a further period of time to reduce the load on the battery from all the many and varied systems.. Hope I have not muddied the water..
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Not sure if it’s been mentioned on this thread but don’t u guys just switch it off via the cutout switch?
2002 Aero 8 S1 2023 Plus 4 (woman’s)
