Topics49,847
Posts837,388
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
That is called a bodge or if you are MMC "a feature". Logically over time if the holes are oversized the feature will appear on all non sleeved wire wheel cars.
Posts: 294 Likes: 5
Posts: 294 Likes: 5 |
Think my issue was more of a "clink", whereas yours sounds more like a proper "clunk"  In my day wheel spacers were a boy-racer bodge for those who couldn't afford the proper wheels (and usually led to eventual wheel bearing failure). Nice work MMC!
Nick Connaught Green Roadster S3 V6
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Not good, something with enough clearance to give an audible 'clunk' will eventually enlarge, especially with the forces of a driven wheel
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
It's actually quite hard to believe that this is real........ Nick
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
It's actually quite hard to believe that this is real........ Nick It is a Morgan - they always work like this Sir.....
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Those loose spacers would not pass a warrant of fitness in NZ
99 plus 8 indigo
Posts: 13 |
Taken out the play by fitting spacers to reduce clearance as a temporary solution
Plus 4 in Claret Red 3.7 Roadster Crystal Blue Plus 4 in Lapis Blue Plus Four inPalladium Silver
Posts: 13 |
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
As I understand it (apologies if wrong) the "solution" is to fit loose sleeves to bolts that hold adaptor to bolt on wheel hub to better match adaptor hole size. Not a spacer as such therefore.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
If they can't get the holes to match the studs it would be a better solution to fit threaded sleeves. My bathroom light fitting uses threaded sleeves so it isn't rocket science.
The MGBGTV8 wheels used wheel-nuts which had a thick washer, and below that was a straight sided tube section, (part of the nut), which located (with a lot of slack) into holes in the alloy wheel centre, which do not have inserts. There was no tapered location at the centre. This was BL at it's best. In order to get some semblance of centralisation, I used to nip up with two MGB standard taper nuts, before fitting the real nuts. It was bad engineering.
