2 members (paulgolfcar, +8Rich), 353 guests, and 62 robots.
Topics49,860
Posts837,486
Jonny72
CJB Offline
Ah yes, the front bolt on mine must have been fitted before the engine was dropped in as it was head to the front so impossible to remove and very tight. I removed the whole supporting frame from the front of the block to remove the alternator when replacing my water pump.
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
I have a collection of old spanners that lend themselves to modification for awkward jobs. They came into our steelworks scrapyard as rejects when I worked there in the 1970’s. By sifting through I got a nice range of sizes. Most had one good end but mangled other end.
One came in handy to take the lever arm damper off my 4/4 after grinding it to fit into the gap for one bolt. I have slimmed down a couple of others and bent a couple to give offsets.
I also still have some nails that came in. I found some good ones amongst the bad.
