4 members (gaston, Zach, piquet, Chris Cosher), 342 guests, and 46 robots.
+8Rich 92
Topics49,838
Posts837,294
Page 2 of 4 1 2 3 4
TBM #716998 06/09/21 12:55 PM
As a matter if interest I am just about in the process of manufacturing replacement stainless steel hinge pins.(pricing TBA) Also I have taken over the manufacture of stainless steel bonnet extensions from John Taylor of Phoenix Design Services.
I hope it’s OK to mention it on this thread? I will also put it on the For Sale section.
If any of the forum members are interested let me know.
Regards, Paul.
TBM #716999 06/09/21 12:59 PM
X
X
I like to press pins out in a parallel vice with a nut and hexnut as pressing tools.
All pins will give up.
Greets René
2018 plus4 (sports green)
Fuel.inj #717002 06/09/21 02:17 PM
TBM Offline OP
Regards, Paul.
I'd be interested if my other plans don't work.
TBM #717063 06/09/21 07:53 PM
TBM, I spoke to a restorer today whose built some very nice Mogs, he uses Paul Beck Vintage Supplies
CooperMan #717070 06/09/21 08:33 PM
TBM Offline OP
Thank you - just checked their website. From what I can see, their Brass hinges are the same price as MR.
TBM #717079 06/09/21 09:24 PM
From the dimensions given above the M7 x 80 bolts used on Citroen 2CVs to fix the lamp bracket to chassis might be suitable for adaption.
Available from 2CV specialists such as Der Franzose at around £2 each.
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
TBM #717164 07/09/21 03:26 PM
My Librands door stays have ceased to function properly (did they ever ?). At 12 years old and after just 3 months of ownership, parking on a slight incline or in a strong-ish prevailing wind blows the doors shut. On the basis that there are usually several wrong solutions, which of these seems a good cure ?
~ squeeze the two sides of the stay closer together (risks marking the s/steel)
~ replace the "roller" (is there a custom-made one ?)
~ if not, then a slightly larger-size piece of brass or bronze (or fibre) tube ?
~ tighten something else ?
TBM Offline OP
I have a similar issue - I believe option 1 is the solution. I'll remove, use some rubber to protect the steel and give a squeeze with some adjustable pliers or similar.
Definitely solution 1 is correct - just protect the stainless with rubber or the like - best to remove the hinge and squeeze but be careful not to overdo it!! Don't ask how I know!!!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Fuel.inj I'd be interested in a set of oversize hinge pins (7mm?). I had planned to make some with 7mm rod and graft on the domed top of the originals somehow.
Page 2 of 4 1 2 3 4
