Topics49,838
Posts837,296
Posts: 938 Likes: 18
Posts: 938 Likes: 18 |
As a matter if interest I am just about in the process of manufacturing replacement stainless steel hinge pins.(pricing TBA) Also I have taken over the manufacture of stainless steel bonnet extensions from John Taylor of Phoenix Design Services. I hope it’s OK to mention it on this thread? I will also put it on the For Sale section. If any of the forum members are interested let me know. Regards, Paul.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I like to press pins out in a parallel vice with a nut and hexnut as pressing tools.
All pins will give up.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
As a matter if interest I am just about in the process of manufacturing replacement stainless steel hinge pins.(pricing TBA) Also I have taken over the manufacture of stainless steel bonnet extensions from John Taylor of Phoenix Design Services. I hope it’s OK to mention it on this thread? I will also put it on the For Sale section. If any of the forum members are interested let me know. Regards, Paul. I'd be interested if my other plans don't work.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
TBM, I spoke to a restorer today whose built some very nice Mogs, he uses Paul Beck Vintage Supplies
TBM, I spoke to a restorer today whose built some very nice Mogs, he uses Paul Beck Vintage Supplies Thank you - just checked their website. From what I can see, their Brass hinges are the same price as MR.
Posts: 172 |
From the dimensions given above the M7 x 80 bolts used on Citroen 2CVs to fix the lamp bracket to chassis might be suitable for adaption. Available from 2CV specialists such as Der Franzose at around £2 each.
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
My Librands door stays have ceased to function properly (did they ever ?). At 12 years old and after just 3 months of ownership, parking on a slight incline or in a strong-ish prevailing wind blows the doors shut. On the basis that there are usually several wrong solutions, which of these seems a good cure ? ~ squeeze the two sides of the stay closer together (risks marking the s/steel) ~ replace the "roller" (is there a custom-made one ?) ~ if not, then a slightly larger-size piece of brass or bronze (or fibre) tube ? ~ tighten something else ? ![[Linked Image]](https://www.tm-img.com/images/2021/09/07/Stay----left.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
I have a similar issue - I believe option 1 is the solution. I'll remove, use some rubber to protect the steel and give a squeeze with some adjustable pliers or similar.
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Definitely solution 1 is correct - just protect the stainless with rubber or the like - best to remove the hinge and squeeze but be careful not to overdo it!! Don't ask how I know!!!!
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
Fuel.inj I'd be interested in a set of oversize hinge pins (7mm?). I had planned to make some with 7mm rod and graft on the domed top of the originals somehow.
